Author Topic: 4" backspacing 15x8 wheels with 275 tires in the rear?  (Read 1212 times)
Offline Dutchallenger
« on: May 22, 2014 - 03:39:45 PM »
I have a set of restored Cragar Keystone Klassics ready for new rubber. They are 15x7 front and 15x8 rear, all with 4 inch backspacing.
Available tires choices over here are limited to 235/60R15 front and either 255/60 or 275/60. Rear axle is 8.75, stock Rallye springs.
Would the 275/60 clear the fender lips with this backspacing?
Offline HP_Cuda
  • Mopar or No Car!
Re: 4" backspacing 15x8 wheels with 275 tires in the rear?
« Reply #1 on: May 22, 2014 - 03:41:02 PM »
I believe you want 4.5" backspacing then you could easily get the 275's in the rear.
FWIW
« Reply #2 on: May 22, 2014 - 03:47:59 PM »
That's what I found yeah. But the Keystones come in 4". Don't want the tires to rub the wheel wells or lips.
Experiences anyone?
Offline blown motor
« Reply #3 on: May 22, 2014 - 05:14:48 PM »
I have 255s with 3.75 backspace. They will rub on a good bounce, especially with someone in the back seat. You gain a 1/4" on the backspace but have a wider tire so likely about the same thing.
« Reply #4 on: May 23, 2014 - 01:53:38 AM »
@blown motor:
Rub inside wheel wells or fender lips?
Offline blown motor
« Reply #5 on: May 23, 2014 - 08:27:20 AM »
Fender lip. I've been trimming it but it's still not enough. Might have to add a leaf. 1 1/2" space on the inside. You really need a 4 1/2" backspace or a B-body rear axle.
« Reply #6 on: May 24, 2014 - 02:35:58 PM »
Went with 245/60 rear and 225/60 front. Distinct look and for sure no rubbing.
Offline blown motor
« Reply #7 on: May 24, 2014 - 04:29:54 PM »
THat should look cool  :ylsuper:
