Author Topic: Over charging problem  (Read 880 times)
Offline 6packCuda
« on: May 24, 2014 - 03:42:29 PM »
The last couple of times I drove my Cuda last year I noticed the amp gauge was reading a little higher than usual towards the charge side. This spring I by-passed the ammeter and installed a volt meter. It showing about 15-15.5 Volts all the time. I verified the voltage with my fluke on the battery. Here's where it gets interesting. I then decided to run a 10 gauge bypass wire from the alternator stud to the starter relay. With this bypass wire hooked up, it now idles at 16V and goes up to 17+ with rpms. I tried a different regulator with with the same results. Ran a jumper wire from the regulator housing directly to the battery -. No change. Tried a different alternator, no change. Cleaned up the  battery-engine block ground, no change. I'm baffled. Why is it over charging and why did voltage increase so much with the bypass wire?
Re: Over charging problem
« Reply #1 on: May 24, 2014 - 06:07:53 PM »
It's the voltage regulator 'seeing' a lower voltage than actual or a faulty regulator. Poor connections in the bulkhead connector can cause it. Check your bulkhead connector and the grounding of the VR. Small voltage drops across poor connections can cause the VR to 'see' a different voltage than what is actually being o/p to the battery.
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: May 24, 2014 - 07:50:00 PM »
Think that sums it up :)
Steve
Offline ShelbyDogg
« Reply #3 on: May 24, 2014 - 08:25:38 PM »
Did you try another alternator?
All the voltage regulator does is adjust how much ground the green wire is getting. If the alternator is internally grounding it's own field, it doesn't matter if you put 5 different regulators on it.
Offline 6packCuda
« Reply #4 on: May 24, 2014 - 10:55:29 PM »
Checked the bulkhead connectors and found the connectors for the ammeter are corroded and melted. I'm confident this is causing my problem. Going to drill out the connectors and run a new wire through the bulkhead and splice it in to the original wires.
Offline 6packCuda
« Reply #5 on: May 25, 2014 - 05:59:21 PM »
Problem solved :cooldancing:. Now it idles at about 12.5V and holds steady at about 14.2 with rpms.
Offline JayBee
« Reply #6 on: May 25, 2014 - 06:06:40 PM »
Thanks for the update. Information and solutions like this are priceless.
John
1970 Barracuda convertible
2014 Toyota Avalon
