Author Topic: Where Does this Go?  (Read 1963 times)
Offline dpcd67
Where Does this Go?
« on: May 27, 2014 - 10:29:39 AM »
My photographic memory has failed. Again. I seem to remember taking this off the bell housing but I forgot which bolt it goes on. It might be for the reverse switch? Help, please, from those with better memories.  thanks.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline HP_Cuda
  • Mopar or No Car!
Re: Where Does this Go?
« Reply #1 on: May 27, 2014 - 11:46:44 AM »
I believe you are correct, it's for the cabling for the reverse switch light and neutral safety switch cables.
Offline dpcd67
« Reply #2 on: May 27, 2014 - 01:23:23 PM »
Ok, now which bell housing bolt does it go on?; I am ready to torque those on today.
1963 Dodge M37 (3)
I ain't done yet.
Offline CudamanTom
« Reply #3 on: May 27, 2014 - 01:29:29 PM »
On Hoover Auto Parts I found this info. Maybe it can be of help?
66-74 Mopar Wire Retaining Clip for the Reverse Light Switch Wiring on 3 and 4-Speed Transmissions. They mount on the underside cover retaining bolts 1 at rear top and 1 at the rear upper location.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline dpcd67
« Reply #4 on: May 27, 2014 - 03:51:29 PM »
Hmmm; one at rear top; if that means the top bell housing bolt; got that. One at rear upper? I will have to think about what that means.
thanks.
1963 Dodge M37 (3)
I ain't done yet.
Offline CudamanTom
« Reply #5 on: May 27, 2014 - 07:11:18 PM »
thanks.
I know. Clear as mud right?  :smilielol:
Offline dpcd67
« Reply #6 on: May 28, 2014 - 02:17:20 PM »
Yeah, I even took pictures of where everything was on the engine but I can't see them in my crappy photos.  Anyone?  I want to put them back in the OEM place.
1963 Dodge M37 (3)
I ain't done yet.
Offline 73RallyeChallenger
« Reply #7 on: May 28, 2014 - 06:47:42 PM »
Offline dpcd67
« Reply #8 on: May 28, 2014 - 10:26:33 PM »
Top right bell housing bolt is where I think I see one. right?
1963 Dodge M37 (3)
I ain't done yet.
« Reply #9 on: May 28, 2014 - 10:37:28 PM »
Yes, positioned at the 2 O'Clock position on the bell housing (RH side)
« Reply #10 on: May 28, 2014 - 11:07:17 PM »
Big Blocks are 11 O Clock.
Offline CudamanTom
« Reply #11 on: May 29, 2014 - 07:10:42 AM »
Thanks for providing that Mike  :clapping:
I'll be referring to this as well.
Very usefull indeed.  :2thumbs:
Offline dpcd67
« Reply #12 on: May 29, 2014 - 02:45:04 PM »
Mine is a 340 but I will assume those are in the same place.
thanks,
1963 Dodge M37 (3)
I ain't done yet.
