Author Topic: clock setting cable  (Read 539 times)
Offline antonellomopar
clock setting cable
« on: May 28, 2014 - 02:07:03 PM »
I have put together the rally dash in my Barracuda conv....everything mounted on the bench and finally bolted on the car. Everything looks great...except I didnt have the clock cable, so it was not mounted. Now I have received it...and was wondering how to bolt on the dash. Shall I take the gauges off the car to properly mount the cable? Or is there some shortcut to avoid takeing all apart?
Thank you
Offline quapman
    • Auto-Grip on Facebook
Re: clock setting cable
« Reply #1 on: May 31, 2014 - 08:29:40 AM »
You'll have to drop the steering column, remove the light panel and gauge bezel, which also involves wiggling around the (loose) switch panel, but you shouldn't have to take the cluster out.
