Author Topic: 1972 dodge challenger voltage limiter  (Read 937 times)
Offline BoomerSoonerVA
  • Newbie
« on: May 30, 2014 - 10:14:08 PM »
So when I went to start my car today I saw smoke coming from the voltage limiter.  So i started the car and my fuel, temp, and oil gauge didn't work.  I replaced it with another limiter I have.  I put it in and then I noticed my Volt started going from center to need charge back and forth.  After trouble shooting it is down to I remove the temp gauge out of the system and the Volt goes to normal but the oil and fuel max out.
Re: 1972 dodge challenger voltage limiter
« Reply #1 on: May 31, 2014 - 09:24:12 AM »
Make sure the gauge is isolated from the dash frame , there are fiber insulators in there to prevent it touching the frame
