Author Topic: Finally home....71 Cuda  (Read 2964 times)
Offline ryangtogtx
Re: Finally home....71 Cuda
« Reply #15 on: June 03, 2014 - 08:26:30 AM »
Haven't installed the new Rev-N-Ator yet.  The first one I received was defective.
Offline ryangtogtx
« Reply #16 on: June 03, 2014 - 08:27:42 AM »
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #17 on: June 03, 2014 - 10:16:51 AM »
On a side note, does anyone run Autometer Gauges with a console?  If so, opionions on where to mount tach, etc. would be appreciated.
I'm having my standard gauges renewed by Redline.  They are mounting an oil pressure gauge where the blank spot is and a tach next to the speedo an moving the fuel where the Alt meter is since that is basically worthless IMO.  They are also re-calibrating the speedo, resetting the odometer since I am putting in a new engine, drive train and suspension, and polishing up the plastic lens.  Here is their link if you are interested: http://www.redlinegaugeworks.com/contact.asp
Offline BFM_Cuda
« Reply #18 on: June 03, 2014 - 10:19:27 AM »
Some dimly lit shots from inside my garage after I got home from the Mopars in the Park show.
Very nice looking car Ryan, you drove right by me when you pulled into your spot at the Mopar show. Car looks and sounds great!
Offline ragtopdodge
« Reply #19 on: June 08, 2014 - 03:26:05 PM »
Sweet ride!  Although I wouldn't have drilled holes in that firewall to mount that orange box.
My $0.02.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline anlauto
« Reply #20 on: June 08, 2014 - 06:08:43 PM »
How do you know that the ECU box is not in it's factory location ?
Electronic Ignition was an option on the 340 half way through 1971 and this car has it in the proper location using the proper mounting bracket.
Offline dutch
« Reply #21 on: June 08, 2014 - 06:21:47 PM »
beauty  :drool:
*** Bart ***
Offline usraptr
« Reply #22 on: June 08, 2014 - 09:20:41 PM »
Very nicely done on all accounts!   :2thumbs:   :ylsuper:
(Edited 8-1-17)
Offline Sean
    • My Cuda Restore
« Reply #23 on: June 08, 2014 - 10:24:17 PM »
Stunning looking car!  Beautiful!!!   :cooldancing:
Sean
