Author Topic: So.. My header slaps my T bar  (Read 3641 times)
Offline cudabob496
Re: So.. My header slaps my T bar
« Reply #15 on: June 04, 2014 - 05:52:23 PM »
True.
I tend to not be a fan of poly transmission mounts, however. This is because if you take some flex out of the mounting system at this point, you run the risk of the aluminum trans case becoming the flex point and cracking it if a motor mount fails.
$100 Shumacher Torque Strap is a great device!
2011 Kawasaki Z1000
« Reply #16 on: June 04, 2014 - 05:57:22 PM »
Or a $5 piece of chain. :2cents:
Offline cudabob496
« Reply #17 on: June 04, 2014 - 07:04:14 PM »
that would work, but the torque strap is adjustable, with rubber busings.
http://www.engine-swaps.com/Pages/ProductsType/TorqueStraps.html
« Last Edit: June 04, 2014 - 07:06:53 PM by cudabob496 »
2011 Kawasaki Z1000
Offline stinger
« Reply #18 on: June 04, 2014 - 08:41:47 PM »
my chain was free  :bigsmile:
« Reply #19 on: June 05, 2014 - 10:25:02 AM »
I've made my own with two $5 rod ends and a piece of pipe. Looks more purposeful than chain, although I have used chain before as well.
Offline stinger
« Reply #20 on: June 08, 2014 - 08:54:41 AM »
Fixed! I installed the poly mount and made things worse as the old mount had some up and down movement to it the new mount raised up the tail of the trans and moved the whole exhaust into the t bars and frame. so........ I lowered the transmount and cross member some and found enough room.
took the car for a spin and no driveline issues for what I could tell. :bigsmile:
Offline dutch
« Reply #21 on: June 08, 2014 - 11:22:29 AM »
how fast did you drive after that mod?
*** Bart ***
Offline stinger
« Reply #22 on: June 08, 2014 - 12:01:11 PM »
up to 60 mph
