Author Topic: Question on timing in general  (Read 874 times)
Offline NorthWestcuda
« on: June 03, 2014 - 11:45:41 AM »
How do find out what my overall total timing actually is?  All I have is an 30 year old sun timing light with a factory damper and timing pointer on timing chain cover on the 440.  Do I need to add timing tape to my harmonic balancer, purchase an aftermarket damper with full timing markets or buy a new advanced timing light that shows total timing (don't really know what that is though).
Sorry about the basic question
Thanks, Jim
« Last Edit: June 03, 2014 - 02:16:53 PM by NorthWestcuda »
1973 Cuda, 440 engine
1972 Chevy 4x4 PU stepside
2003 Ford F-350 Diesel
Re: Question on timing in general
« Reply #1 on: June 03, 2014 - 03:48:16 PM »
This was written by a local club member, an engineer, might give you some good pointers
http://tvmoparclub.com/files/tech/Mopar%20Timing.pdf
Offline Racer57
« Reply #2 on: June 03, 2014 - 04:31:56 PM »
You could buy/rent a digital timing light. Hook it up and then start turning the knob until the damper and pointer line up on TDC. Then see what the light says the degrees are.
« Reply #3 on: June 04, 2014 - 09:34:13 AM »
put a cut or a mark on the damper @ 2 3/8" clockwise from the factory mark & that is 36* so you can use your normal timing light & 0 on the scale is 36 , +2 is 38 etc
« Reply #4 on: June 05, 2014 - 02:15:18 PM »
Great Idea.  Now thats using the old noggin.
Thanks guys.
