Author Topic: 340 flywheel  (Read 1003 times)
Offline Rich G
340 flywheel
« on: June 04, 2014 - 12:17:27 PM »
Is the a way to tell the difference between a neutral balanced flywheel apart from a non neutral wheel for a 340 engine by looking at it?
Re: 340 flywheel
« Reply #1 on: June 04, 2014 - 04:31:40 PM »
Yes , balanced flywheels will have holes drilled in face towards the crank , neutral balanced will be left as cast
Offline Rich G
Re: 340 flywheel
« Reply #2 on: June 06, 2014 - 01:39:33 PM »
Thanks, Oh crap I think I have the wrong one on. Well I hope so anyway because I have a hell of a vibration in the engine!
Re: 340 flywheel
« Reply #3 on: June 06, 2014 - 09:06:09 PM »
That would do it !!
Offline ToxicWolf
Re: 340 flywheel
« Reply #4 on: June 06, 2014 - 09:21:55 PM »
That would do it !!
  :iagree:  Major vibration when you get the wrong one on there.  I know.   :pullinghair:
Re: 340 flywheel
« Reply #5 on: June 06, 2014 - 09:47:34 PM »
You should take a look at what Crankshaft balancer you have as well.
http://www.moparts.org/Tech/Archive/smallblock/5.html
Offline Rich G
Re: 340 flywheel
« Reply #6 on: June 26, 2014 - 12:06:41 AM »
Finally got the new flywheel. That was the problem!!! Another lesson learned. Might make it to Carlisle after all.
