Author Topic: cooling parts needed.. AAR  (Read 2747 times)
Offline gleasmja
« on: June 04, 2014 - 05:50:42 PM »
I'm looking for a 7 blade fan setup for my 70 AAR if anyone has one, P/N 2863216, clutch also p/n 2806070 and the fan shroud 2998326.
Thanks
Jon
« Last Edit: June 09, 2014 - 07:36:47 PM by gleasmja »
Offline brotow
  • There really is a Challenger in the backround
Re: 7 blade fan setup
« Reply #1 on: June 05, 2014 - 06:01:44 AM »
I'm looking for a 7 blade fan setup for my 70 AAR if anyone has one.
Thanks
Jon
This should be the original fan from the 1974 challenger 360 with air.  The clutch will be included with the fan. As for price I don't know what it is worth to ask for a fair price.
Here is my photobucket link to more pictures of the fan and clutch.  And I can get a measurement if you need it,  You can probably check the part number on it and find the application, size,....
http://s1131.photobucket.com/user/brotow1/library/1974%20challenger%20radiator%20fan
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline gleasmja
« Reply #2 on: June 05, 2014 - 07:36:58 PM »
thanks, but that's to big for my application.
Re: cooling parts needed.. AAR
« Reply #4 on: June 09, 2014 - 08:20:57 PM »
Yes,
26" shroud does all engines from 318 to Hemi.
Offline anlauto
« Reply #5 on: June 09, 2014 - 08:43:13 PM »
 :iagree: Yup...shroud is the easy (cheap) part of your problem.
« Reply #6 on: June 09, 2014 - 08:54:26 PM »
You'll need these as well.
http://www.ebay.com/itm/70-71-A-B-C-E-Body-Cuda-26-OEM-Radiator-Shroud-Bolt-Set-/400709291129?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5d4c228c79#ht_556wt_758
Pull up gently while tightening to make sure fan doesn't hit shroud.
They are very close.
Offline gleasmja
« Reply #7 on: June 10, 2014 - 12:08:14 AM »
I'm noticing that!!!! :pullinghair:
« Reply #8 on: June 10, 2014 - 12:20:22 AM »
The OEM clutch fans can be re built. But at a cost of time.
You're looking at least a 1 year lead time.
It was by a guy named I believe, Fred Oliva in FL.
Tony's Parts sells reproductions.
« Last Edit: June 10, 2014 - 12:36:43 AM by Topcat »
Offline gleasmja
« Reply #9 on: June 10, 2014 - 08:50:55 PM »
Vintage Automotive Research
2602 NW 94th Ave
Coral Springs Fl.
Just contact Fred Oliva at foliva@gate.net or call him at (954)756-1161
I've found this searching around but it's from 2004, and they said the numbers no good. trying the email now.  Anyone got newer information??
e-mail doesn't work either...????
« Last Edit: June 10, 2014 - 08:53:46 PM by gleasmja »
« Reply #10 on: June 10, 2014 - 09:05:31 PM »
Fred was an older (salty) gentleman when I last dealt with him years back.
I also tried finding his contact info and it has gone away.
Might try sending him a letter if the e-mail doesn't work and see if that works?
Scott at Harms Auto is very up on who could be doing fan clutch restorations.
There maybe somebody else who restores these perhaps.
Offline gleasmja
« Reply #11 on: July 16, 2014 - 06:29:32 PM »
another detail question?  Should the fan have the stamped part number or embossed part number?
Thanks
« Reply #12 on: August 15, 2014 - 12:59:18 AM »
Fans had a stamped number with a Made in Canada stamping in white ink.
Any luck contacting Fred?
Offline gleasmja
« Reply #13 on: August 15, 2014 - 01:11:05 AM »
No luck contacting Fred.  But my friend tracked me one down at Carlisle.  Stamped part number, but repainted so no stamp.  And a good clutch to boot.
« Reply #14 on: August 15, 2014 - 01:56:13 AM »
3462112 is the 71' clutch very close to the 70' 2806070.
Slight differences.
