Author Topic: Dash voltgage limiter problems.  (Read 1374 times)
Offline Racer57
« on: June 07, 2014 - 04:29:11 PM »
70 Cuda Rallye gauges
Gas, oil and water temp gauges don't work. There is 12v power to the solid state voltage limiter and 1.2v coming out. I'm assuming that's not enough ?
Here's the real issue.... I had an old original that worked perfect and replaced it last summer with a solid state one that a friend had. Gauges didn't work.  I assumed it was bad,  so I put the old original one back in and everything worked fine. Then this winter when I had everything back out I bought a new one from Roseville thinking its best to stay ahead. At times it works, then it goes dead. I first thought the spade connectors were loose, but after fixing them nothing changed. Do I have bad luck or is there something else going on ?
Re: Dash voltgage limiter problems.
« Reply #1 on: June 07, 2014 - 05:01:57 PM »
Correct. You need 5V out of a solid state. If you went through a couple, maybe your dash grounding may be an issue. Make sure the four screws holding your cluster to the dash frame have a clean ground connection. I've had a solid state (home made) limiter in place for ten years so I know they should last longer than you are experiencing.
« Reply #2 on: June 07, 2014 - 08:59:55 PM »
I'm in the same exact problem.
Put in my old one and they started working.
I noticed a screw adjustment on the limiter.
Would that be something to try or test?
« Reply #3 on: June 07, 2014 - 10:52:16 PM »
If there is an adjustment screw, definitely check the o/p of the reg and set it to 5v.
« Reply #4 on: June 07, 2014 - 11:21:02 PM »
that would be great if I knew how much to adjust it to.
Offline ToxicWolf
« Reply #5 on: June 08, 2014 - 12:06:56 AM »
If you have a voltmeter you could hook it up and see what changes while you turn the screw.   :dunno:
« Reply #6 on: June 08, 2014 - 01:08:41 AM »
O.K I'll look into that. I have an SLA battery for bench test.
« Reply #7 on: June 08, 2014 - 08:17:56 AM »
Connect the +ve battery lead to the input of the limiter and the -ve to the case. then put your voltmeter +ve lead on the output connector and the -ve lead to the limiter case. If it were me i'd adjust it for about 5.1 to 5.3volts because when you are bench testing there is no load on the regulator. If instructions came with the limiter regarding voltage setting/checking, it would have been handy, eh?
Offline Racer57
« Reply #8 on: June 08, 2014 - 09:27:43 AM »
I tested the first solid state limiter that I had used that didn't work. It reads 4.94v.  I moved the little screw as far in as possible and as far out as possible with no change in volts. So either the screw does not adjust the volts, or whatever is wrong with mine has effected that also.
I don't feel like taking my dash out for the umpteenth time so I made leads with male/female spade connectors on each end to fit my old original limiter and the wires going to it. I then bolted the limiter and noise suppressor along with a grounding wire together. I unplugged the leads from the one on the dash after twisting myself into positions that my 60yr old body didn't like and plugged in the leads from my "new" set up, fastened the ground wire to the radio strap and everything now works perfect. This coming winter I'll pull the dash and do it right.
« Last Edit: June 08, 2014 - 10:40:43 AM by Racer57 »
