Author Topic: thought I'd share (headliner)  (Read 2757 times)
Offline Ebodiesonly
« on: June 07, 2014 - 10:24:35 PM »
I don't know if anyone else knows this, but out of necessity I learned this trick while installing my first bow type headliner. Instead of headliner clips you can go to office max and buy a tub of mini paper clamps. You can use them for keeping the liner tight horizontally. The great thing is they're easily movable as they have tge wires that allow you to release and reposition them until the headliner is perfect. Once it is just right and your satisfied you can squeeze tge little wires and they come off leaving the black mini clip! Hope this helps someone, I know it made my install a breeze...of course if this is common knowledge just ignore me
Re: thought I'd share (headliner)
« Reply #1 on: June 07, 2014 - 10:49:34 PM »
 :2thumbs:
The big ones that are an inch wide are the one's to check out.
More spring load.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: June 08, 2014 - 09:01:33 AM »
Thanks for the tip!!  This is on my project list for my '71 Chally and will be my first headliner too.
Offline Jesus H Chrysler
« Reply #3 on: June 08, 2014 - 09:06:40 AM »
I'm in the middle of doing this now.  I didn't think the office clips would be strong enough, so I got the big ones at the hardware store.  Now that it's glued tight, I might have to use your idea and see if I can get the smaller ones to secure it under the trim.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline Ebodiesonly
« Reply #4 on: June 08, 2014 - 12:10:02 PM »
Yes Jesus the minis will hold and they do fit under the trim. Ill send in a few pics of mine.
Offline Ebodiesonly
« Reply #5 on: June 08, 2014 - 03:20:14 PM »
clips installed, first liner.
« Reply #6 on: June 08, 2014 - 03:58:36 PM »
Nice!  You wouldn't happen to have a pic of the clips you used?
{OO /===\ OO}
(OO==> <==OO)
Offline Ebodiesonly
« Reply #7 on: June 08, 2014 - 04:12:22 PM »
no, but if you go to office max to their office essentials area by the paper clips and staplers youll see the black mini paper clamps with the silver opening wires. just pull your liner tight, clamp the clip on, then squeeze the wires together to leave the clamp in place once you have everything just like you want....tight. dont do like i did, be sure to replace your seat belts, mirrors, and visors as you go. theyre a pain in the ass to find once the liner is installed and tight...lol
heres the link for them
http://www.officemax.com/office-supplies/clips-fasteners-rubberbands/bulldog-binder-clips/product-ARS21692?R=21258915&ssp=true&fromUrl=TnRwYz0xJkQ9YmxhY2srbWljcm8rYmluZGVyK2NsaXBzJk50cHI9MSZOdHk9MSZOdHg9bW9kZSUyYm1hdGNoYWxscGFydGlhbCZOdGs9RGVmYXVsdCZOPTAmTm89MCZEeD1tb2RlJTJibWF0Y2hhbGxwYXJ0aWFsJk50dD1ibGFjayttaWNybytiaW5kZXIrY2xpcHM
« Reply #8 on: June 08, 2014 - 04:17:00 PM »
Thanks.  I am familiar with the clips, but the ones we use at work are WAY too big to fit under the trim.  I'll take a look at the smaller ones and see if they have any that match the stock clips I took off
{OO /===\ OO}
(OO==> <==OO)
Offline Ebodiesonly
« Reply #9 on: June 08, 2014 - 04:44:37 PM »
They do....its what I did. Theyre the micro size
Offline CHL2T
  • Handle it, man!
« Reply #10 on: June 20, 2014 - 06:46:30 PM »
Shoot, almost makes me want to re do the liner in the Charger.... almost
Offline Ebodiesonly
« Reply #11 on: June 20, 2014 - 06:52:28 PM »
The mini clips are an exact size match....and it made the install so easy. Everytime I look up at that new headliner I laugh it looks so good. I give all the credit to those clips. It was my first liner and it looks factory new.
Offline RallyeChally
« Reply #12 on: June 20, 2014 - 08:03:50 PM »
Great tip ... Thanks for the post !   :cheers:
« Reply #13 on: June 21, 2014 - 01:49:50 PM »
Yep I did it and worked like a charm.  I'll try to get pics as I put it back together.  Thanks again!
{OO /===\ OO}
(OO==> <==OO)
Offline ToxicWolf
« Reply #14 on: June 21, 2014 - 02:05:36 PM »
I like it.   :popcorn:
