Author Topic: MSD Blaster 2 coil out of spec?  (Read 894 times)
Offline stinger
« on: June 08, 2014 - 01:56:42 PM »
did an ohm test on the coil due to my car breaks up very consistently @ 5300 rpm.
spec primary .7 ohms,test .7 ohms. primary spec 4.7K ohm,test 10.68k ohms.
my ignition consists of an old 6A cd box, new firecore distributor,new firecore wires and the old msd coil.
could I have found the culprit? car runs great up to 5300 rpm's and I was considering a spring swap.
Offline stinger
Re: MSD Blaster 2 coil out of spec?
« Reply #1 on: June 10, 2014 - 06:39:00 PM »
don't you hat it when no one replies? I ordered a firecore e coil,Thanx!
« Reply #2 on: June 10, 2014 - 06:42:41 PM »
Yea hate when I've stumped the board....good luck with that new coil.
Offline jhaag
« Reply #3 on: June 10, 2014 - 11:55:02 PM »
best place for info like that is manufacturers tech line.
love 70 Challengers
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: June 11, 2014 - 02:35:55 PM »
If you have higher resistance than a stock one then yeah it's time to get a new one.
They are fairly cheap in comparison to other items so it should be an easy fix.
