Author Topic: Start Challenger without dash?  (Read 867 times)
Offline daaboots
« on: June 09, 2014 - 01:24:20 PM »
I have the dash pulled out of my Challenger, but I need to move the car now. Is there any way to start it without putting the dash back in?
Also, does anyone have a good wiring diagram for a 74 Challenger?
Re: Start Challenger without dash?
« Reply #1 on: June 09, 2014 - 02:52:07 PM »
put a jumper wire from the positive battery terminal to the input side of the ballast resistor, crank motor by shorting terminals on the starter relay.
basic diagrams here  http://www.mymopar.com/index.php?pid=24
Offline anlauto
« Reply #2 on: June 09, 2014 - 02:56:07 PM »
Check and see if the steering column is still in the car first... :smilielol:
Offline daaboots
« Reply #3 on: June 09, 2014 - 03:53:33 PM »
Thanks Bullitt. And which is the input side?
Yes, the steering wheel and pedals are present  :naughty:
« Reply #4 on: June 09, 2014 - 05:29:07 PM »
   Blue wire.
« Reply #5 on: June 09, 2014 - 06:56:42 PM »
I think you need to connect the red & black ammeter wires together
Offline Racer57
« Reply #6 on: June 09, 2014 - 07:11:32 PM »
I think the only thing you need is to hook the amp wires together.
Isn't that the only thing you need to do ?
