Author Topic: Will New Distributor = Old Tach  (Read 983 times)
Offline flagcraig
« on: June 10, 2014 - 05:07:05 PM »
Is there a current distributor on the market ie MSD or Mallory that will work with my existing factory tach without doing any conversion to the tach?  Looking for a good solid distributor with todays technology that won't break the bank and gives me very few headaches.
It's a factory 1972 340 motor.
Thanks for any suggestions.
Offline cudabob496
« Last Edit: June 10, 2014 - 06:14:53 PM by cudabob496 »
2011 Kawasaki Z1000
Re: Will New Distributor = Old Tach
« Reply #2 on: June 11, 2014 - 08:00:50 AM »
The new factory type dist are fully adjustable Available from Mopar or Mancini or Roseville
« Last Edit: June 11, 2014 - 02:43:49 PM by Chryco Psycho »
Offline flagcraig
« Reply #3 on: June 11, 2014 - 12:19:56 PM »
Thanks for the info.  I saw the adapter in a couple of my Mopar catalogs and will go in that direction.
Any recommendations on a distributor would be appreciated.  Budget is $200-$300 for this plus the adapter.
Thanks.
Offline cudabob496
« Reply #4 on: June 11, 2014 - 06:58:28 PM »
Thanks.
MSD is good! But I had to drill a hole in side of distributor cap to keep moisture from building up. Other than  that,
it has been flawless for 14 years. And its easy to install different timing curves.
« Last Edit: June 11, 2014 - 09:38:59 PM by cudabob496 »
2011 Kawasaki Z1000
