Another pinion angle question
Author Topic: Another pinion angle question  (Read 2446 times)
Re: Another pinion angle question
« Reply #15 on: June 24, 2014 - 10:10:12 PM »
interesting, from the yoke ujoint mounting serface or between the mounts in the cross shaft area?
ill post some pictures soon
Just to be sure, I went off the actual mounting surface of the u-joint. Removed the u-joint and stuck my ipod in there. I couldn't find any conclusive evidence that the other areas were actually parallel to the actual mounting surface.
And for the transmission, when the d-shaft was removed, I went off the end of the o/p shaft.
« Last Edit: June 28, 2014 - 07:39:06 AM by dodj »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #16 on: June 28, 2014 - 05:51:35 PM »
Im getting close  :bigsmile:
How much clearance should I want on the transmission end of the tunnel and the drive shaft?
I don't want the drive shaft to hit the tunnel at full suspension compression, it should be minimal on the transmission end but it will need some room.
Go Fast & Have Fun...
« Reply #17 on: June 28, 2014 - 07:52:36 PM »
I don't know how close it can be, but i wouldn't think the tailshaft moves up and down very much. Trans mount would hold it pretty close to not moving?
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #18 on: June 28, 2014 - 07:54:02 PM »
I have a 1 inch clearance between the drive shaft and the top of my tunnel with the suspension fully compressed.
« Last Edit: June 28, 2014 - 09:26:25 PM by johns cuda shop »
« Reply #19 on: July 19, 2014 - 02:02:39 PM »
Any update Scott?
