Author Topic: Tac/shift light problems  (Read 1383 times)
Offline Crazy440
« on: April 19, 2005 - 01:27:26 PM »
I have an after-market tac and a stand alone shift light.  I've double checked all the wiring and connections.  Everything is hooked properly.  The problem is, neither work.  They both were working fine.  Now, nothing. I have power to both and a  good ground and I checked the trigger wire, from the coil and it's ok.  Any ideas?  Can't believe both would go bad at the same time.
Offline Crazy440
Re: Tac/shift light problems
« Reply #1 on: April 21, 2005 - 10:23:52 AM »
No one has any ideas?
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #2 on: April 21, 2005 - 11:31:18 AM »
DISCONNECT THE SHIFT LITE AND SEE IF TACH WORKS
Offline Crazy440
« Reply #3 on: April 21, 2005 - 10:50:19 PM »
I've done both the shift light and the tac seperate and neither work. I'm lost.  Don't understand how both could go bad, at the same time.
Thanks for your idea.
