Author Topic: Last call for Help!!!---> 72cudamaan needs some parts!  (Read 5759 times)
Re: Last call for Help!!!---> 72cudamaan needs some parts!
« Reply #30 on: June 17, 2014 - 12:52:54 AM »
It would depend what calipers are used , 70 pin style the hose threads right into the caliper , 72 slider type use a different hose , Rock Auto should list both by year . All  years were front mount as I recall .
 From my experience the mini starter will fit through the header if they are TTI headers , not sure if they are Dougs though
 you could just plug the heater hose ports  but the fittings are not hard to find & hose is cheap 1/2 pipe by 3" should work , even a hardware store pipe nipple could be used .
 With the Serp system are going to run A/C on the car again in the future , if so you need a compressor minimum to route the single belt , it would be simpler to just use V belts short term I think .
 Use Only a Melling oil pump high pressure std volume , Jegs should have them ,
 Carb will mount with 5/16 bolts studs are preferred into alum though .
 Any of the car magazines might be able to pull some parts in return for the story maybe ! Any one else we can think of that might sponsor some parts ? :1zhelp:
« Reply #31 on: June 17, 2014 - 08:24:53 AM »
They are pin style.
« Reply #32 on: June 17, 2014 - 08:29:01 AM »
Raybestos BH35017 Rockauto has them for 12.86 each
Offline VTMopar
« Reply #33 on: June 17, 2014 - 09:35:04 AM »
Negative Battery Cable mailed this am to above noted address.
VT Mopar
VT MOPAR
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #34 on: June 17, 2014 - 02:25:31 PM »
Thanks VT Mopar!!!
Dan
Offline CUDA JAS
  • vroooooom!
« Reply #35 on: June 17, 2014 - 04:27:08 PM »
Spare tire hold down bracket and bolt - would this be the same as a 74 cuda?  If so I may have one.
Steering column retaining clip - what are you looking for here...I have a couple of columns and willing to give what ever is needed off of them.
Wish I could do more to help, but my parts stash is too small to be called a parts stash.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline crocha617
« Reply #36 on: June 17, 2014 - 04:39:28 PM »
727 Trans Cooling lines ordered. Please cross off the list
« Reply #37 on: June 17, 2014 - 04:47:04 PM »
 It may not be identical but I am sure it would work
I may be wrong but I am thinking the wide mount bracket that bolts to the column with 4 bolts & goes over the 2 studs to hold the column up , these use special washers approx. 3/4" across with a knurled edge inside & out .
Jason
Offline DMZ73
« Reply #38 on: June 17, 2014 - 05:16:06 PM »
"Steering column retaining clip - what are you looking for here...I have a couple of columns and willing to give what ever is needed off of them.
I may be wrong but I am thinking the wide mount bracket that bolts to the column with 4 bolts & goes over the 2 studs to hold the column up , these use special washers approx. 3/4" across with a knurled edge inside & out ."
We have the 3 bolts that mount the pplate to the floor, and the bracket that mounts to that, but is there a retention clip on this thing?
reference pic or manual pic would help-That way I can site what I am referring to.
Dan
« Reply #39 on: June 17, 2014 - 05:23:00 PM »
Dan
This... not sure if other years have it but mine did?
http://restorationpartssource.com/store/product173520.html
Offline DMZ73
« Reply #40 on: June 17, 2014 - 07:51:47 PM »
Yep, didn't see one on his car, and as a matter of fact, I don't have one on mine either, lol
BAH!!! He's missing the large rubber O-ring seal too. Damn, I knew something else was awry.
dmz73
« Last Edit: June 17, 2014 - 09:55:00 PM by DMZ73 »
Offline BIGSHCLUNK
« Reply #41 on: June 17, 2014 - 08:00:17 PM »
Got one on mine  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #42 on: June 17, 2014 - 08:11:17 PM »
BAH!!! He's missing the large rubber I-ring seal too. Damn, I knew something else was awry.
dmz73
If your referring to the big o ring type seal that goes between the plates on the firewall, I did see one in Andy's stash !
Offline CUDA JAS
  • vroooooom!
« Reply #43 on: June 17, 2014 - 08:15:35 PM »
this is from my 74 FSM...does it help.
BTW my 74 does not have the clip either...the plastic retainer has integral clips.
Jason
74 'cuda 360/727
« Reply #44 on: June 17, 2014 - 08:30:51 PM »
Jason
Thanks, Must be one of those 1970 only deals then?  :dunno:
