Author Topic: 1970 challenger starter relay wiring  (Read 6381 times)
Offline Franta
« on: June 13, 2014 - 03:31:49 PM »
Yesterday while I was at work my father-in-law AKA "the grim reaper of cars" tried to jump my challenger to move it. Somehow he fried the wire from the battery to the starter relay switch and melted the wire labeled fuseable link.  Does this wire run to the ignition switch and do I have to put an in-line fuse in when replacing this wire, if so what size?  Thanks
Re: 1970 challenger starter relay wiring
« Reply #1 on: June 13, 2014 - 09:25:05 PM »
Ugg , did the fusable link save the wiring through the firewall ??
 Yes you need to replace the fusable link , I forget what the gauge is though ,
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: June 14, 2014 - 12:15:46 AM »
I know if you have.a 55-60A alternator it will be 10G with a 14G fuseable link
Offline Franta
« Reply #3 on: June 14, 2014 - 01:25:26 PM »
The fuseable link saved most the wiring. I got some 10g wire with a 12g fuseable link I will probably put it all together tomorrow.  I haven't done a whole lot of wiring so I'm hoping I don't screw something up
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: June 14, 2014 - 01:55:06 PM »
Ok I have to ask - How do you fry the wire from the battery to the starter with a jump?
Did he reverse neg and pos and short the hell out of it?
Offline Franta
« Reply #5 on: June 15, 2014 - 02:09:08 PM »
I have no idea how it happened, I do know I wasn't very happy when I heard about it
Offline ammo
« Reply #6 on: June 16, 2014 - 07:34:46 AM »
Does your wife has a sister?  I could swear we have the same father in law.   :swear:
1973 dodge challenger
Offline Franta
« Reply #7 on: August 05, 2014 - 12:36:41 PM »
Finally got some free time to go through things and found the hot coming off the starter relay switch fried at the block going into the firewall.  Both sides are toast.  Am I going to have to get a whole new wiring harness to repair this?
« Reply #8 on: August 05, 2014 - 12:44:47 PM »
You can buy just the bulkhead connector.  You don't have to buy the entire harness.  Now is the time to make some electrical upgrades.  Have you read this article?
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: August 05, 2014 - 01:09:03 PM »
Yep looks like the ammeter strikes again!
*cue the star wars music*
Offline anlauto
« Reply #10 on: August 05, 2014 - 01:09:06 PM »
I would replace all the wiring with new from M&H. Also replace the Father-in-law :2thumbs:
Offline Franta
« Reply #11 on: August 05, 2014 - 04:44:33 PM »
Can't find a bulk head connector anywhere.  Does anyone know where I can find them
« Reply #12 on: August 05, 2014 - 07:01:48 PM »
M&H / Year one will sell the whole harness , EVans wiring might sell parts
Offline Franta
« Reply #13 on: August 05, 2014 - 09:54:25 PM »
I don't know that I want to replace the whole harness.  If I pull the dash ill probably pull the whole interior and while the interior is out I might as well start doing a little body work...it's just a chain of events that's leads to spending way too much money
« Reply #14 on: August 06, 2014 - 08:24:27 AM »
 :grinyes:  yep I hear that!
What's M&H got a link?
« Last Edit: August 06, 2014 - 08:26:14 AM by brads70 »
