Author Topic: 1970 challenger starter relay wiring  (Read 6380 times)
Re: 1970 challenger starter relay wiring
« Reply #15 on: August 06, 2014 - 09:18:17 AM »
I looked up bulkhead connectors at Evan's and they don't sell E-body ones.....just A,B and C-body)  M&H has an exclusive contract with Year One.  Anyone else selling their harnesses is buying them from Year One and reselling them.  I don't think Evan's offers "main dash harnesses".  You'll have to buy one from Year One if you are going to replace the entire thing.  Hopefully you can find a used harness that still has a good bulkhead connector.  The other "option" is to see if there is a good unused slot in the connector and move that wire to a different place.  You could also just bypass the connector and run a new wire straight through.
« Last Edit: August 06, 2014 - 09:28:05 AM by burdar »
Offline anlauto
« Reply #16 on: August 06, 2014 - 11:57:40 AM »
At this point that is what I was going to suggest. The bulkhead and the connector are screwed, might as well run a drill through it and just run the wire straight through... :2cents:
