Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Identifying pistons?
« previous
next »
Print
Pages:
1
2
Author
Topic: Identifying pistons? (Read 1831 times)
Loa
Jr. Member
Re: Identifying pistons?
Reply #15 on:
June 23, 2014 - 11:54:03 AM »
Ok. As soon as I install a new tach I'll give it a try.
Also, I just realized that the cam I installed 2 months ago was made for lower compression engines (thought it was a 73 340)...
Loa
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #16 on:
June 23, 2014 - 12:27:35 PM »
well the cam will be helping to build cylinder pressure so ti should may a lot of torque if it doesn't detonate
Logged
Loa
Jr. Member
Reply #17 on:
June 23, 2014 - 12:31:06 PM »
Ok. I'm planning on having the engine retimed and the carb reset. Anything I should do differently knowing that the cam is not ideal? (it's Comp Cam's 20-212-2).
Thanks for the help and info.
Loa
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #18 on:
June 23, 2014 - 01:07:02 PM »
You can get a lot of power from tuning , it takes time to get everything tuned correctly
Logged
Loa
Jr. Member
Reply #19 on:
June 23, 2014 - 01:48:34 PM »
Thanks. Got your other threads for timing and carb, and will post back once everything is done (won't be soon!).
Loa
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
