Transmission Fluid - What to use
Author Topic: Transmission Fluid - What to use  (Read 748 times)
Offline 74 challenge
« on: June 16, 2014 - 08:02:29 AM »
I have been trying to search down some mysterious leaks on my trans and so far I have failed to identify any. After getting the car up to temperature I realised the trans was low on fluid. What should i use in my A904?
I have done some preliminary Google searching and I guess there seems to be 2 trains of thought ATF-4 or F type.
What is the difference? what is everyone else running?
Also what is people's opinions on additives? what do you recomend?
thanks guys! i am trying to get the car running wel for the 28th of June so I can attend a car show.
1-8-4-3-6-5-7-2
Re: Transmission Fluid - What to use
« Reply #1 on: June 16, 2014 - 11:34:21 AM »
F type is better IF the trans is new , otherwise ATF3 is probably what is in there now
« Reply #2 on: June 16, 2014 - 03:12:09 PM »
I have no reason to beleive this transmission was rebuilt in the last 15 years. Still shifts smooth so I think I will run some ATF-3.
1-8-4-3-6-5-7-2
Offline 360FISH
  • BS23H3B567746
« Reply #3 on: June 25, 2014 - 04:38:44 PM »
I've been running ATF-4 in mine with no issues...  shifts great and seems to be holding up to abuse.
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
