teach me on cam specs please...
Author Topic: teach me on cam specs please...  (Read 805 times)
Offline dutch
« on: June 16, 2014 - 04:46:53 PM »
my cuda had the 440 in it when I bought it, and it ran pretty good too. When the time came to do some engine work, I decided to tear it down and see what was inside. The machinework needed was done by a shop and I put everything back together myself. new rings, bearings ignition carb rebuild ect. but funds were tight and parts measured within tolerance went back in. So did the cam.
I`m learning more and more about these engines since I`m alone on this and have no one around with knowledge to help me with engine stuff. Now I`m at the point where I`d like to understand a bit more about cams and their relatives... I know nothing about cams and what the specs mean... so.... here`s what I`ve got:
Engle K65 hydraulic.  B112.
I sent an e-mail to Engle since I had a hard time finding any specs. They replied:
 .236’ duration at .040” 112 lobe center .332”lift at the cam .498”valve lift 278’running duration
way cool, but to me it could have been written in Turkish ...  :violin:
Here is the rest of specs on my engine:
1970 440hp
forged crank
forged trw pistons with valve cut outs. 10-1 comp ? ( not measured)
stock 906 heads
stock rockers ,double valve springs
edelbrock torker intake
souped up 750 holley.
mopar perf. ingnition
Headers
727+dana 4;10
So, can anyone shine a light on the cam specs and how it relates to the rest of my set up please?
« Last Edit: June 16, 2014 - 06:49:15 PM by dutch »
*** Bart ***
Re: teach me on cam specs please...
« Reply #1 on: June 16, 2014 - 06:42:25 PM »
Start here http://www.cuda-challenger.com/cc/index.php?topic=819.0
The cam should be a great street cam , decent vacuum & drivability , good lift per duration , probably runs out of power around 5500 rpm
Offline dutch
« Reply #2 on: June 16, 2014 - 06:48:58 PM »
so.... I keep telling people anything can be found here on cc....  :bricks1:  :lol:
thanks Neil... got some reading to do.
any comments on the overall combo?
*** Bart ***
« Reply #3 on: June 16, 2014 - 07:04:23 PM »
Should work well with your combo except for the 4.10 gears maybe , you will go through the powerband very quickly + the carb is small with 4.10s
« Last Edit: June 16, 2014 - 09:33:39 PM by Chryco Psycho »
Offline cudabob496
2011 Kawasaki Z1000
