Attn: Final parts list! Updated 6/26/14
Author Topic: Attn: Final parts list! Updated 6/26/14  (Read 26381 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: June 16, 2014 - 10:47:43 PM »
I have this posted under
"Last call for help" under the general forum topic.
Here is the list based on the results of the build party.
I will keep this updated.
We already have a few people willing to contribute.
Please see below:
Friends:
We are working on the mission critical list.
These are the items we deem most critical to getting the car completed create a fully functional vehicle.
There are many things we still need to get. Please see below.
We can make this happen a few ways.
If you want to donate money via PayPal, you should PayPal Andy's son Doug. (Dknox1@emich.edu)
If you want to call and make an anonymous monetary donation for parts in Andy's name, we may be able to work that out with MoparDave. I will call to confirm a method.
If you want to buy or send anything on the list, please send it to Andy's Address,
You can address it to:
The Knox Family
2420 Walter Dr.
Ann Arbor Mi. 48103
**Please note:**
If you want to send something or purchase something, please communicate it on the board right away!
We need to be able to keep track of these parts, and cross it off the list.
**My Canadian friends:**
I have a close friend who comes across daily. I may have you ship parts to my friend so he can bring them across. I trust him with my life.
Here is the latest last critical items to finish the “Last Wish Cuda”
440 Water pump- ( hi volume; run in either direction)
440 aluminum Intake manifold (4BB)-----------------------------------------------donated by ToxicWolf
440 intake seal kit--------------------------------------------------------------------donated by ToxicWolf
440 oil pump-Use Only a Melling oil pump------------------------------------------donation by Chryco
 high pressure std volume -----------------------------------------------------------donation by Chryco
727 trans cooler lines ----------------------------------------------------------------donated by crocha617
Lokar kickdown linkage kit ---------------------------------------------------------- donation pending from Bullitt
throttle return springs----------------------------------------------------------------donated by Jimmynick
intake manifold bolts-----------------------------------------------------------------donated by Jimmynick
Accelerator cable---------------------------------------------------------------------donated by topcat
1 Coil wire-----------------------------------------------------------------------------donated by Murray
Dual exhaust tips---------------------------------------------------------------------4Cruzin to donate
Oil dipstick (Milodon)-----------------------------------------------------------------donated by BIGS
1972 Gas cap[/s]---------------------------------------------------------------------donation pending by Murray
Spare tire hold down bracket and bolt----------------------------------------------donated by JAS
Speedo cable--------------------------------------------------------------------------donated by Dutch
Negative battery cable----------------------------------------------------------------donated by VT Mopar
Orange ECU--------------------------------------------------------------------------- donated by edl94
Ballast resistor-------------------------------------------------------------------------donated by BIGS
Distributor------------------------------------------------------------------------------donated by MEK
727 trans dipstick----------------------------------------------------------------------donation pending by Murray
Carb  5/16 bolts studs ----------------------------------------------------------------donated by Jimmynick
Radiator hoses
Need 4BB throttle bracket
Need water pump bolts
accelerator linkage
440 coolant hoses from firewall to block (A/C car)
New 440 Mini starter
Aluminum 727 Trans flywheel cover
1 U-joint
Need Positive battery cable
Power brake booster foam gasket from bracket to firewall
emergency brake cable kit
front seat belt ass'y retractors and scabbards (Bolts to floor) (Black)
***Serpentine belt system pulleys (Is anyone familiar with SDC Concepts Serp belt kit?)***
***Serpentine belt***
Ignition system/electrical
***A pigtail for NiponDenso*** (only if for serpentine belt setup)
backup plan-
V belt until serp system is complete
use stock alternator brackets/mounts
water pump pulley
standard alternator,
crank pulley
Hardware needed:
2 more transmission crossmember bolts
Headlight bucket hardware
Center cap screw/fastener kit
Midland-Ross brake booster bell crank pin
Steering tube seal (big o-ring)
Steering column retaining clip?
10 long wheel studs
1/8 wheel spacer, large Mopar 5 x 4.5” bolt pattern
1/4 wheel spacer, large Mopar 5 x 4.5” bolt pattern
Other non-critical items:
15 x __ Wide wheel trim rings (rear)
15 x __ wide wheel trim rings front
Magnaflow S.S. Exhaust system- 4Cruzin to donate flowmasters (partial)
If there are any questions, please don't hesitate to call or text me.
Dan Zimmermann
1-248-709-8273
dmz73
« Last Edit: June 26, 2014 - 10:02:58 AM by DMZ73 »
Offline ToxicWolf
Re: Attn: Final parts list!
« Reply #1 on: June 16, 2014 - 10:57:38 PM »
I will be contacting Dave tomorrow to see if he has the intake manifold and intake seal kit.
« Reply #2 on: June 17, 2014 - 01:01:43 AM »
Get a Fel Pro 1215 intake gasket if possible
 Holley Street Dominator would be my pick for intake $247 new from Jegs , they might donate one if we ask
Offline ToxicWolf
« Reply #3 on: June 17, 2014 - 01:03:37 AM »
Sounds good.  I'll check on it.
Offline dutch
« Reply #4 on: June 17, 2014 - 03:28:14 AM »
Dan,  I checked the speedo cable. It worked fine but looked like crap, so I ordered a new one. Should be there in a few days. Please let me know if it does...
*** Bart ***
Offline BIGSHCLUNK
« Reply #5 on: June 17, 2014 - 09:44:35 AM »
Dan, do we need a 2 terminal or 4 terminal ballast resistor?
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline DMZ73
« Reply #6 on: June 17, 2014 - 12:18:52 PM »
BIGS - good question.
I never opened his harness to check.
Dan
« Reply #7 on: June 17, 2014 - 12:34:16 PM »
2 terminal . all new ECUs have only 4 pins so the second side  of the ballast would never be used
« Reply #8 on: June 17, 2014 - 12:41:18 PM »
This is the response from Rock Auto
I am very sorry to hear of the loss of your friend.  Your selfless efforts to continue his legacy through the completion of his project is heartwarming and inspirational.
 I will pass on your request to the person here who would best handle your request for parts.  And ask them to keep me up to date to hopefully help share Andy's car with our newsletter readers.
Thank You,
 Flamur Adili
Offline dutch
« Reply #9 on: June 17, 2014 - 12:48:06 PM »
I got confirmation the cable is shipped  :2thumbs:
*** Bart ***
Offline ToxicWolf
« Reply #10 on: June 17, 2014 - 01:08:06 PM »
Jegs will have these out tomorrow to the family address. (Manifold and seals)
« Last Edit: June 17, 2014 - 03:21:45 PM by ToxicWolf »
« Reply #11 on: June 17, 2014 - 01:09:22 PM »
Awesome  :2thumbs:
Offline edl94
  • She Cuda
« Reply #12 on: June 17, 2014 - 01:29:39 PM »
 I did not know Andy but I want to help out so I just ordered a Mopar Performance P4120505 orange ECU from Jeggs and it will be shipped to the family address. So please cross it off of the list.
Offline dutch
« Reply #13 on: June 17, 2014 - 01:54:41 PM »
list is getting shorter by the minute.... how cool is that  :clapping:
*** Bart ***
Offline BIGSHCLUNK
« Reply #14 on: June 17, 2014 - 03:15:48 PM »
I have a 2 terminal here, I'll send it w the dipstick!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
