Attn: Final parts list! Updated 6/26/14
Author Topic: Attn: Final parts list! Updated 6/26/14  (Read 26358 times)
Re: Attn: Final parts list!
« Reply #45 on: June 20, 2014 - 11:40:17 AM »
did you get exhaust ? I have not heard anything from TTi
Offline cwestra
« Reply #46 on: June 20, 2014 - 12:21:23 PM »
Was there a final decision on a Paypal account designated for this?  I'd like to kick in a bit.
Corey - in Northern Indiana
Offline blown motor
« Reply #47 on: June 20, 2014 - 01:30:45 PM »
Just talked to my tranny guy. He said he sets up lots of performance cars without the flywheel cover. Dirt and moisture getting in is not a problem and the tranny runs 15-20* cooler due to greater air flow around the converter. He thinks he could find a cover if we want one. Your thoughts please guys.
He is also supplying the dipstick and tube  :bananasmi
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #48 on: June 20, 2014 - 01:53:15 PM »
Are you wanting a 3 inch or a 2.5 inch exhaust set for Andy's car?
Go Fast & Have Fun...
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #49 on: June 20, 2014 - 01:57:33 PM »
Here is Doug's paypal info:
Dknox1@emich.edu
dmz73
« Reply #50 on: June 20, 2014 - 02:56:56 PM »
« Reply #51 on: June 20, 2014 - 04:03:44 PM »
I have four headlight bucket assy's out of a 72-4 Challenger. Is that what you mean by headlight hardware?
I send them if that is what you need.
Offline DMZ73
« Reply #52 on: June 20, 2014 - 05:24:03 PM »
I think 2.5" would do nicely.
I think that's what his collectors are anyway.
Dan
dmz73
Offline DMZ73
« Reply #53 on: June 20, 2014 - 05:26:05 PM »
Y'know, I'm not entirely sure.
I need the fasteners that attach the headlight frames to the fender buckets. I also need the adjusters. I think the adjusters are standard anyway, so I'm sure those could work.
Then again, I should consult a manual before I say yes..
Dan
dmz73
« Reply #54 on: June 20, 2014 - 05:28:20 PM »
Dan
dmz73
I got new ones at Roseville for my car it was like $20 so by the time he ships them there it would be cheaper to buy new ones?
Offline BIGSHCLUNK
« Reply #55 on: June 20, 2014 - 08:44:33 PM »
Dan
dmz73
Seems that's what I remember too.  :clueless:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 4Cruizn
  • HEMI FISH
« Reply #56 on: June 20, 2014 - 09:19:12 PM »
I believe that is what my flowmasters are as well.if he has a rear valance that need cuda exhaust tips  I have some of those as well.
Offline p-zero
« Reply #57 on: June 21, 2014 - 08:31:30 AM »
 Hey Dan, need a bit more info on a couple of things.
Need 4BB throttle bracket
Is this a MOPAR specific bracket or can this be fabbed up/use aftermarket?
Need water pump bolts
Do you know the size, thread pitch and length?
accelerator linkage
Factory or aftermarket? If aftermarket do you have a part number?
440 coolant hoses from firewall to block (A/C car)
The heater hoses are just bulk hose, just need a diameter and cut to length.
1 U-joint
What's the exact application for this? Year, make, model for the u-joint or is it custom? (Sorry, my knowledge of MOPAR's is, relatively, limited)
727 trans dipstick (Which one does MoparDave recommend?)
What year is the trans?
Carb  5/16 bolts studs
 Is there going to be a spacer between the carb and the intake? If so, how thick is it?
Steeering column retaining clip?
 Do you have a pic of the clip?
10 long wheel studs
How long do they need to be exactly? I believe these are sold by size rather than application?
Positive battery cable
How long does it need to be, and what gauge wire is preferred? (2 awg, 4 awg?)
 And good call on the exhaust. 2.5" is the way to go. If you ran dual 3" the car would lose a lot of low end torque. One 3" pipe flows more than two 2.5" pipes.
 -Pete.
Offline p-zero
« Reply #58 on: June 21, 2014 - 09:22:55 AM »
 Got some leads on the trans dipstick (is a tube needed as well?), and the water pump bolts.
« Reply #59 on: June 21, 2014 - 10:17:49 AM »
1- T bracket is Mopar specific , Mancini has some aftermarket that work also though
2 - water pump bolts are 3/8 coarse thread , length is apprx 3 " but need confirmation as some are longer for alternator & PS mounting , Mancini mayhave a kit for this but if you go serpentine belt everything will change
3- I think they chose to use Lokar accelerator kit , this would eliminate #1 also
4- heater hose is generally 5/8" , 6 feet would be enough
5- 7260 is the smaller joint 2 1/8" inside , 7290 is larger 2 5/8" inside the yolk , need to know which size to get
6- ?
7- ?
8- ?
9- ?
10 - I would order the factory cable from Dave @ Roseville , it will have the proper pigtails etc  & with the - cable I am not sure what you have but make sure it has a second pigtail to ground on the rad wall for the headlights & body ground
