Author Topic: A/C wire gromet  (Read 1231 times)
Offline tony 73
A/C wire gromet
« on: June 18, 2014 - 05:51:41 AM »
where does a/c wire gromet go through the firewall
Offline FY1Cuda
Re: A/C wire gromet
« Reply #1 on: June 18, 2014 - 05:14:30 PM »
On a '70 the green blower motor wire connects to the bukhead connectors.
http://www.cuda-challenger.com/cc/index.php?topic=98097.msg977954#new
Offline anlauto
Re: A/C wire gromet
« Reply #2 on: June 18, 2014 - 06:12:55 PM »
I couldn't find any info on it either, but I know that the green wire does not go back "in" the car. :2cents:
Offline unotre
Re: A/C wire gromet
« Reply #3 on: June 22, 2014 - 10:28:55 PM »
Found the hole for the grommet. If you look up under the dash, it's a few inches straight above where the steering column clamps to the firewall. And if you're looking from the front in the engine compartment, it's to the left of and slightly obscured by the power brake booster.   :thumbsup:
« Last Edit: June 23, 2014 - 02:30:34 AM by unotre »
Offline FY1Cuda
Re: A/C wire gromet
« Reply #4 on: June 23, 2014 - 11:05:37 AM »
The blower motor is powered by a wire that runs to the #4 spot of the bulkhead connector. The  holes in the firewall are for other things.
Offline anlauto
Re: A/C wire gromet
« Reply #5 on: June 23, 2014 - 12:58:13 PM »
I think A/C cars are different :2cents:
Offline FY1Cuda
Re: A/C wire gromet
« Reply #6 on: June 23, 2014 - 02:26:53 PM »
I don't profess to be an expert on '73 E-bodies, but our '70 Challenger is an A/C car, and the blower switch connects to the blower through the bulkhead connector.
Offline Katfish
  • 70 Challenger
Re: A/C wire gromet
« Reply #7 on: June 23, 2014 - 04:08:37 PM »
Same here, easy to go to mymopar and check the wd.
This is a repeat of another post, same answer that time too
Offline unotre
Re: A/C wire gromet
« Reply #8 on: June 23, 2014 - 08:08:00 PM »
That's how it was done on 70 and 71 I think. In 72 or 73-74 they went with a separate harness for the A/C blower which used a grommet. Here's the diagram from the '74 manual:
Offline FY1Cuda
Re: A/C wire gromet
« Reply #9 on: June 23, 2014 - 11:41:23 PM »
Good find. I stand corrected.
