well, got it in, and painted. $25 of material. Board angles
up from bottom of pumpkin to rear bumper. Have 3 strips of metal 7 inches apart, 3 ft long,
and two inches high, to help direct airflow. For now board is only 2 ft wide,
and about 3.5 ft long, and nestled between the dual exhaust pipes. With this
initial mockup, can now cut a piece that is wider and wraps around 3 inch exhaust pipes.
On each side of pumpkin, there is a small pipe bracket on the board, through which I passed large tie wraps,
and have tie wraps around axel. Tie wraps are the big ones, with 175 pound breaking strength.
Was gonna use large hose clamps. Tie wraps allow suspension to flex. Other end of board bolts
to upper bracket that held rear valance. Jury rigged, but should stay in place. Time to hit the road, and see
if anything falls off.
