ok, bought a 10 ft sheet metal rain gutter from Home Depot for $6.
Cut lengthwise, and mounted one section under side rocker panel,
to act as side skirt. The section in the picture now is about 5 ft long, and held
on by 6 sheet metal screws (#12s I think). Will complete this side, and the other,
then paint satin black, so hardly noticeable, but a sturdy 3 inch side skirt!
Basically will run from front wheel well to rear wheel well.
The gutter has a sharp straight side, and a curved side. I choose the curved side
for safety, as the straight side would be like a giant knife!! Slip off the jack, and you would
get the big ginzo knife!!
Above the skirt is the normal chrome side strip that came on 72 Cuda's.
So, when this is done, will have front spoiler and splitter, belly pan from splittler to oil pan,
belly pan from header collector to mufflers, diffuser in back, and these side skirts. All of which, from a short distance,
should not stand out at all, as to distract from the normal Cuda look.
since about 14% of air drag comes from front tires, last aero project will be to continue the front spoiler around each side
to deflect air away from tires. Still thinking about how to do this.
