TF 727 doesn´t shift into the 3 rd gear
Author Topic: TF 727 doesn´t shift into the 3 rd gear  (Read 787 times)
Offline brasil
« on: June 19, 2014 - 02:18:45 PM »
Hello Folks....
as I wrote in the newbee Corner..I ve bought a 73 Challenger...with a TF 727 Transmisson....     the transmisson doestn ´t shift into the 3 rd gear...
Reseve ,First and second gear  works....  when I drive with 55 mph and go into the kickdown the Transmission downshifts...into the first...so the car slows down ( of course )
Where should I start to look at... ? Kickdownlinkage ?
The oil is red..and there is no "burt smell " also..
Thank you for your help
Greetings Juergen
Offline edl94
  • She Cuda
Re: TF 727 doesn´t shift into the 3 rd gear
« Reply #1 on: June 19, 2014 - 02:54:58 PM »
I would check the shifter linkage first and make sure that when it is in drive it really is in drive. Then the kickdown linkage
Offline brasil
« Reply #2 on: June 19, 2014 - 03:39:07 PM »
Thank you edl94
I will check all the settings on saturday...   what do you think of changing the oil /filter too ?  and when I am there...I can check the  kickdown and rear band adjustment too..
Greetings Juergen
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: TF 727 doesn�t shift into the 3 rd gear
« Reply #3 on: June 20, 2014 - 08:53:32 AM »
I recently tried to install a shift kit in my 727 and found that someone had been in there before me.  I went ahead with my shift kit, but when I buttoned up the valve body it would not shift into 3rd gear.  I found out I was missing a bearing but did not know what else was wrong, so I ended up buying a whole new valve body instead of risking it.  No problems any more!
