Author Topic: 1971 383 Fuel Filter Location?  (Read 961 times)
Offline anlauto
« on: June 19, 2014 - 09:56:15 PM »
On a OE correct 1971 383 4bbl E Body....Where is the fuel filter located and does anybody have a picture ? :picture:
Offline cudabob496
2011 Kawasaki Z1000
Offline anlauto
Re: 1971 383 Fuel Filter Location?
« Reply #2 on: June 19, 2014 - 10:17:17 PM »
So is this right ?
Offline cudabob496
« Reply #3 on: June 19, 2014 - 10:52:36 PM »
don't know, but i would not have the fuel line running for a foot or two in front of engine,
where it gets heated by the air from the radiator.  I have mine coming from the side. Or,
you could insulate the line.
2011 Kawasaki Z1000
« Reply #4 on: June 20, 2014 - 12:06:29 AM »
the fuel line would do a U from the fuel pump & come up near the heater hoses around the dist & into the carb , the vapor separator was only used on 3/8 line cars with the extra return line but the filter I believe was positioned in the same area , of course the line would be different depending if the 383 was equipped with a Holley carb / front connection or an AVS / right rear connection .
