Author Topic: AAR Cuda brake question  (Read 1254 times)
Offline anlauto
« on: June 21, 2014 - 10:11:48 PM »
Please help me with a brain fart....
I bought my AAR in a million pieces and I can't find a certain piece so I'm questioning myself on whether or not it uses one.
The car has POWER assisted front disc brakes with 11" rear drum as it should.
The proportioning valve mounted below the master cylinder is that funky 2 piece design which splits off the front brakes.
My question is: Should the car also have the brass block mounted further back on the driver's side frame rail requiring the 2 piece front to rear brake line ?
Re: AAR Cuda brake question
« Reply #1 on: June 21, 2014 - 10:36:13 PM »
To my knowledge yes , all 70 disc brake cars had the 2 piece system
Offline cwestra
« Reply #2 on: June 22, 2014 - 12:24:51 PM »
This is what it looks like in my AAR and I'm pretty sure it is correct.
Corey - in Northern Indiana
Offline anlauto
« Reply #3 on: June 22, 2014 - 12:32:03 PM »
Yes thank you...I understand that part no problem, but can you look and see if there is a brass "T" shaped block about 12" back on the frame rail...that's what I'm wondering about.
Offline Rich G
« Reply #4 on: June 26, 2014 - 12:22:35 AM »
I put an AAR together for a friend of mine and it did not have another block other then the 2 pictured.
Offline Moparparts
« Reply #5 on: June 28, 2014 - 08:29:40 PM »
AAR and T/A did not use the tube proportioning valve back on the frame rail
Offline anlauto
« Reply #6 on: June 29, 2014 - 01:41:49 AM »
Well now we have confict :pullinghair:
