Author Topic: Fuel hose/line from pump>carb 383-4bbl 1971 Barracuda  (Read 617 times)
Offline andben
« on: June 23, 2014 - 02:49:36 AM »
I have a stock 383 4 barrel 1971 Barracuda and needs to replace fuel hose from fuelpump (mech) to carb. (they are probably from 1971 so replacing them makes me feel more calm when packing up by babygirl in fontseat).
Which size is best to use?
e-body for life
Re: Fuel hose/line from pump>carb 383-4bbl 1971 Barracuda
« Reply #1 on: June 23, 2014 - 10:42:00 AM »
it should have steel line most of the way up from pump to carb with fittings on both ends & the steel line going directly into the carb if it is Carter or a short 3" piece of hose if it is Holley carb . if you have rubber hose from pump to carb it is wrong but should be 5/16"
Offline andben
« Reply #2 on: June 25, 2014 - 02:19:39 AM »
Ok! Thanks!
e-body for life
