Author Topic: after market fuel gauge,help/info  (Read 780 times)
Offline Dragon383
« on: June 25, 2014 - 12:54:43 AM »
Hello all,
Little info. I bought the car last summer. It had major electric problems. I had three aftermarket gauges when I got it. The fuel gauge was original. It worked.  Over the winter(spring) I got the whole car rewired and running last week. I figured while doing it all, and since my dash was already cut up, I switched to all new gauges. I bought new Auto Meter Gauges. I bought the Cobalt 6113 fuel gauge. 0 ohm empty, 90 ohm full.
I had read that this was the correct ohm level for the factory float/sender.
When I got the car running the gauge showed 1/4 full. That seemed low.  I drove about 55 miles and then put in 10 gallons today. The guage didn't move much while driving the 55 miles. The gauge now shows almost empty :(
Did I buy the wrong ohm gauge?  Is the sender/float messed up? Is there an easy fix or do I need a differnt gauge? Any info on how it all works would be great.
Thanks all
Offline mrbill426
    • All Around Mopars
Re: after market fuel gauge,help/info
« Reply #1 on: June 25, 2014 - 10:42:39 AM »
I believe it is 10 ohms full and 73 ohms empty
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: June 25, 2014 - 10:56:43 AM »
Yep, you bought the wrong gauge...you need the one that matches the above
Offline Dragon383
« Reply #3 on: June 25, 2014 - 02:14:15 PM »
Dang.  I felt this coming.  Not that I don't trust you all, but is there a way to test it?  I looked it up on the interwebs the first time and as we all know now, it did not go so  well.  :(
« Reply #4 on: June 25, 2014 - 05:57:45 PM »
touch the tank wire to a ground, it should read a full tank, but you will need the correct ohm specs to work for your cluster like others pointed out to you
tank your fuel pick up out and get an ohm meter, set it to 20k  then ground one clip to the pick up and the other to the conector on top. With the float hanging down it will have a reading, then lift the float up and look at your reading. you may have to hook the clip to the post and to the float hanger for this test as you will actually be reading continuity from low to full
Offline dutch
« Reply #5 on: June 25, 2014 - 06:08:38 PM »
I use a speedhut gauge. Set full, set empty and done.
*** Bart ***
