Author Topic: Calibrating Tach?  (Read 711 times)
Offline unotre
Calibrating Tach?
« on: June 25, 2014 - 04:54:36 AM »
Is there a way to calibrate/rebuild the rallye tach without sending it off and having someone else do it? My tach is about 400RPM over.
Re: Calibrating Tach?
« Reply #1 on: June 27, 2014 - 10:20:39 PM »
not really most of the fatory ones are inaccurate , mine was also ,, you can install better electronics yourself without sending it away
Offline unotre
« Reply #2 on: June 28, 2014 - 12:12:40 AM »
I did some more searching and found the RTE site.  http://rt-eng.com/rte/index.php/RTE_67-74_Tach_kit
I was about to order the circuit board but then I read the description on there and learned that the factory tach actually has a potentiometer built into it. Have you tried adjusting that pot and did it help at all?
« Reply #3 on: June 29, 2014 - 09:40:20 AM »
not enough , mine was not linear so at idle it was 300 high & at 3000 it was 2500 high
