Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
8 3/4 YOKE SPLINES
« previous
next »
Print
Pages: [
1
Author
Topic: 8 3/4 YOKE SPLINES (Read 615 times)
crewchief
Jr. Member
8 3/4 YOKE SPLINES
on:
June 26, 2014 - 10:09:14 AM »
Does all fine spline 8 3/4 rearend yokes have the big u-joint? If i have big u-joint yoke can it be adapted to smaller driveshaft joints. I see mopar performance has some type of kit.
Logged
Moparal
Permanent Resident
Re: 8 3/4 YOKE SPLINES
Reply #1 on:
June 26, 2014 - 10:25:16 AM »
yes it can, any parts house usually carries them. 7260/7290 very common Ususally you can tell them big / little joint. Car Quest part number is 2-0527
Logged
Katfish
Resident
70 Challenger
Reply #2 on:
June 26, 2014 - 10:34:48 AM »
Logged
crewchief
Jr. Member
Reply #3 on:
June 26, 2014 - 11:51:56 AM »
Thanks for the info!!!
Logged
burdar
Sr. Resident
Reply #4 on:
June 26, 2014 - 11:53:55 AM »
Quote
No. I've got three 8 3/4 center sections. Two are the 489 case and one is the 741 case. All have the fine spline yoke. All take the small U-joint.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
June 27, 2014 - 12:00:14 AM »
I agree small or large U joint yolks are available in 29 or 10 spline but it is fat easier to use a conversion joint instead of swapping the yolk , on a 489 this can destroy the gears if the crush sleeve is not replaced & torqued properly
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
8 3/4 YOKE SPLINES
