Author Topic: Vapor Lock???  (Read 1071 times)
Offline Mark8117
Vapor Lock???
« on: June 27, 2014 - 09:56:11 AM »
Running a 400BB with Eddie intake and 850 carb.  When the car is all warmed up and I get stuck at a light in traffic, it seems like my gas is getting hot and when I hit the gas to go, it will stall.  It will fire back up if I put the pedal to the floor.  The temp gauge does not climb it stays constant.  I have the fuel line wrapped with insulator where it runs past the header.   Does anyone have any thoughts????   Mech Holley fuel pump.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Vapor Lock???
« Reply #1 on: June 27, 2014 - 10:01:53 AM »
If you have hood clearance, I would consider putting in a carb spacer to get a little more room between the intake manifold and carb.  Do you have a return fuel line?
Offline Mark8117
Re: Vapor Lock???
« Reply #2 on: June 27, 2014 - 10:05:25 AM »
Yes, have a spacer on currently, it is the composite style.  Still no improvement... :faint:
Re: Vapor Lock???
« Reply #3 on: June 27, 2014 - 10:36:00 AM »
Is the heat cross over blocked through the intake , a Fel Pro 1214 intake gasket will block it .
 I assume the float level is correct , accelerator pump shot is nor too much & the linkage is tight with no slack in it
Offline cudabob496
Re: Vapor Lock???
« Reply #4 on: June 27, 2014 - 09:13:13 PM »
ya, seems more like a carb adjustment problem, than a hot gas problem.
https://www.youtube.com/watch?v=5_lgTTkXJDM
« Last Edit: June 27, 2014 - 09:15:39 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Rich G
Re: Vapor Lock???
« Reply #5 on: June 27, 2014 - 10:24:05 PM »
Ck the fuel pump push rod. I was having the same problem I thought was vapor lock but it was the rod worn down about 1/2" and was not pumping enough fuel. There is a step on both sides of the rod that should be the same size.
Offline jimynick
Re: Vapor Lock???
« Reply #6 on: June 27, 2014 - 10:57:56 PM »
Some good tips there and there's an aluminum plate about 1/16" thick and about 10" by 12" that you can buy and mount between the carb and manifold to help disburse the heat, as well. Good luck :cheers:
Offline cudabob496
Re: Vapor Lock???
« Reply #7 on: June 28, 2014 - 07:29:46 PM »
these are handy. sending unit just screws into fuel line
http://www.summitracing.com/parts/atm-8761/overview/
2011 Kawasaki Z1000
Offline polarbear123
Re: Vapor Lock???
« Reply #8 on: June 28, 2014 - 07:40:30 PM »
Eddy's run by vacuum at idle check if you have enough. If your vacuum is low it will stall. I had to turn my timing up to get enough to run when it gets hot
Offline Mark8117
Re: Vapor Lock???
« Reply #9 on: June 30, 2014 - 10:18:37 AM »
Ok- Issue seems to have been found.  After warm up, wathced the fuel presure drop.  So we took a hose with a small stream of water while, running we cooled the fuel pump and the pressure climbed right back up to 7-8psi.  So it appears to be some heat sink in the pump.  Changing it out and should solve this issue.
Thanks for all of the input.  We walked through all of them.... :2thumbs:
