Author Topic: Drop / slam into reverse or drive  (Read 789 times)
Offline CUDA JAS
  • vroooooom!
« on: June 27, 2014 - 09:25:34 PM »
I should know this, but I don't, what causes an auto car to drop hard into gear, reverse of drive, from idle.
My 360 idles away and when I pull it down into R or D it hits pretty hard into gear.
Is there any way to fix it??
Jason
74 'cuda 360/727
Just call me a gearhead!
Re: Drop / slam into reverse or drive
« Reply #1 on: June 27, 2014 - 09:54:39 PM »
Lower idle spped , looser converter , there should be a way to slow the accumulater with a stiffer spring internally
Offline jimynick
« Reply #2 on: June 27, 2014 - 11:02:37 PM »
Jas, are you sure it's the trans that's banging? Any slop in either the U-joints or diff?   :dunno:
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: June 28, 2014 - 12:01:27 AM »
hmmm good point...the u joints are all just a couple of years old...could it be in the rear end...it has never been touched??
The idle is currently at 750, stock converter.  Vacuum at idle in drive is around 12.
Jaon
74 'cuda 360/727
