I thought I would start posting the details about my new engine I am building again. Yes, I know I am never happy and always build it, pull it and build another. But this one is special to me...lolo
I will give complete pics of the assembly, as I assemble it after I get out of the hospital Tuesday
I'm shooting for 950 hp or so this time
I started with an aluminum Indy Maxx wet block. Ported B1 original heads with 1.7 rockers and valve springs to hold 900 lift. Ported B1 intake and spacers. I had Comp cams grind me a roller cam .810 in .797 ex 114 lobe center 114 valve angle 296/298 @.050
Diamond gas ported 14.8/1 pistons, Molner rods at 7.100 and molner crank . Moly plasma coated racing rings and Kings hp main bearings with clevite chevy 743 hdx rod bearings. Rod clearance at .0032 and mains at .003
10 qt Milodon dragster pan with dual swivel pick up Milodon aluminum pump Kieth black gear drive system, ati balancer. Msd crank trigger with an MSD locked pro billet distributor. MSD 7al2 with MSD HVC 2 Pro coil, 1150 holley HP ultra dominator, but am considering 2 1050 ultras. Complete Magnafuel 500 series fuel system, and a Mezierie 55gpm water system With home built 2 3/8 headers exiting the fenders with 5 inch collectors.
I have everything here to start my build. I just file fitted the rings to the cylinders, checked the oil rings for .015 clearance and mounted the pistons on the rods. I balanced the crank on a lathe instead of drilling holes in it. It takes quite a few more hrs to do this, but it was something I wanted to do. The head port work was well over 400 cfm on the intake at 800 lift. I will be posting more on this after Tuesday with pictures aswell, once i'm out of the hospital. I am looking forward to getting this built and installed.
