Author Topic: Tach issues...  (Read 893 times)
Offline Loa
Tach issues...
« on: June 28, 2014 - 04:20:10 PM »
[Edit: see further posts]
Hello,
When I got my Challenger last year, the tach was dead. Before having it rebuilt or buying a new one, I wanted to make sure it was dead. It had been left unplugged and I just tried to plug it. I made sure the long screw was on a working 12 volts, and that the shorter bolt was connected to my coil's negative side.
I wasn't hoping for much, but to my surprise, the car won't start at all when the tach's plugged. As soon as I remove it from the coil, the engine starts normally.
Is that indicative of a bad tach, or another problem?
Thanks
Loa
« Last Edit: July 23, 2014 - 11:22:53 AM by Loa »
Offline FY1Cuda
Re: plugging tach prevents engine from starting...
« Reply #1 on: June 28, 2014 - 04:29:03 PM »
Only guessing, but if your tach is shorted internally then the 12v you put to it would be feeding back to the negative side of the coil (preventing the coil from building up a charge). :2cents:
« Last Edit: June 28, 2014 - 04:38:29 PM by FY1Cuda »
Offline Loa
« Reply #2 on: June 28, 2014 - 05:17:58 PM »
Very good guess. After reading your post I did a continuity test between the two screws: they're shorted.
Is it worth it to take the tach apart and look for it?
Loa
Offline FY1Cuda
« Reply #3 on: June 28, 2014 - 10:04:36 PM »
Probably not.  I think your best bet is getting a new innards for it.
http://rt-eng.com/rte/index.php/RTE_67-74_Tach_kit
Offline Loa
« Reply #4 on: July 23, 2014 - 11:22:12 AM »
Hello,
I got the tach board from rt-eng and it still doesn't work. The soldering plan is pretty bad, so I've had to figure a few things out. But at present, the tach needle barely moves when I rev the engine. By barely I mean it goes from 0 to about 400, very slowly. The needle moves freely when I blow on it and returns to 0, I've tried adjusting the little screw, I've checked every contact point for continuity and the coil's resistance is dead on spec.
Added info: I have access to another tach that, while it's very old, was supposed to work. It doesn't on my car, but I don't have access to another classic car to test it. Is it possible to test it on modern cars?
Loa
« Last Edit: July 23, 2014 - 11:23:47 AM by Loa »
Re: Tach issues...
« Reply #5 on: July 23, 2014 - 05:53:38 PM »
Depends how modern , a lot of nw cars have coils right on the spark plugs
Offline miketyler
    • www.miketyler.net
Re: Tach issues...
« Reply #6 on: August 22, 2014 - 07:49:10 AM »
I also bought one of those boards and never got it to work properly. I need to pull the panel back out and fix it as well as my buzzing speedo. It would reach a certain speed and the needle would begin to oscillate so bad that the needle started coming apart.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Azchallengerboy
Re: Tach issues...
« Reply #7 on: August 24, 2014 - 11:12:08 AM »
Hi Guys, my tach shorts out the coil also.  Is the printed circuit board that classic industries sells come from RT?When I order mine up I want to know that I get a board that will work.
Offline Adam
Re: Tach issues...
« Reply #8 on: August 24, 2014 - 10:03:57 PM »
I have used the RT-Eng tach kit on two different tachs with great success; however they were both functioning tachs to begin with... maybe whatever prevented the old tach from working is affecting the new guts..
Offline miketyler
    • www.miketyler.net
Re: Tach issues...
« Reply #9 on: August 24, 2014 - 11:37:20 PM »
Could be right. Mine initially behaved like it had damped movement. Maybe back off the screw on the jewel movement? Need to pull it back out to check voltages
72' Cuda restomod
70 Mustang Mach 1
