Author Topic: Best factory head to port  (Read 562 times)
Offline myrtle
« on: June 28, 2014 - 08:29:13 PM »
Im aiming for a totally stock/stealth look and I am not rue which head responds best to port work. Im also a little confused as to all the different types of factory heads. I know of the 452 open chamber heads, 906 open chamber heads and 516 closed chamber. Which are the most desirable and which pack the most punch after being worked over?
Thank You
1970 GTX. #s Matching Super Track Pack
Offline cudabob496
Re: Best factory head to port
« Reply #1 on: June 28, 2014 - 08:43:58 PM »
after spending a ton of money on portwork, you can probably still find an aluminum head
that will flow better, at much less cost.
To look stock, can always paint the aluminum head.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #2 on: June 28, 2014 - 11:20:39 PM »
Thank You
Muscle Motors use to do a lot of iron head port work, on Mopar heads.
On a diff note: https://www.youtube.com/watch?v=29wIHzwyoMQ
« Last Edit: June 29, 2014 - 05:23:25 AM by cudabob496 »
2011 Kawasaki Z1000
« Reply #3 on: June 29, 2014 - 12:22:54 AM »
It would depend on the current compression , if you can get away with it the 915 or 516 are best as they have the true closed chamber & with .060- .040 piston to head clearance you will have quench which will help kill detonation , Most people will tell you the 516 is useless , but with good port work , hard exhaust seats & large valves they do make power , I have worked over a lot of sets of them with good results .
 If you have to use open chamber the 906 has the best intake port , all of the open chambers are similar often people use the 452 because it has hard exhaust seats but by the time you do a valve job the seats need hard inserts anyway .
 The best production heads were the Max Wedge stage 3 castings good luck finding those !!
