Magnaflow X pipe point up or down
Author Topic: Magnaflow X pipe point up or down  (Read 2353 times)
Offline crash340
« on: June 29, 2014 - 07:42:34 AM »
Hi Fellow Magnaflow people,
Im installing my X pipe Magnaflow system, when installing the X pipe section, the short ends face forward, the long ends go into the mufflers, with regard to the short ends facing forward, once installed, do they point slightly up or slightly down???
I have then during trial fit pointing up, looks ok at this point, if I was to point them down (that is flip the X pipe section) it would lift the pipes and give them more ground clearance but the park brake cables would be tight over the pipes.
Any idea's???
Greg
Greg
73 Cuda
Brisbane, Australia
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Magnaflow X pipe point up or down
« Reply #1 on: June 29, 2014 - 08:52:21 AM »
My TTI H-pipe points down if that helps.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: June 29, 2014 - 09:30:03 AM »
I put mine on pointing down, I used the 3 inch kit and wanted it high and tight..
Go Fast & Have Fun...
Offline crash340
« Reply #3 on: June 29, 2014 - 04:20:06 PM »
Thanks guys,
How did you get around the EB cable problem? or didnt you worry about it?
Greg
73 Cuda
Brisbane, Australia
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: July 01, 2014 - 12:59:28 PM »
With my TTIs i didn't have an EB issue.  What issue are you encountering?
Offline crash340
« Reply #5 on: July 01, 2014 - 05:15:17 PM »
None yet but, right now I have the pipes pointing up which means they are not tucked up super tight and the cables are limiting the pipes going higher a little, let me play with them some over this weekend and I'll take some pics and post.
It's really just the wire hook that attaches to the tranny crossmember that holds the cables that go back either side
Greg
73 Cuda
Brisbane, Australia
Offline dfrazz
« Reply #6 on: July 01, 2014 - 07:44:38 PM »
Mine H-pipe clears - no issues
Offline crash340
« Reply #7 on: July 01, 2014 - 08:08:09 PM »
Dfrazz
the Cuda has a slightly different cable set up,, thanks for posting pics, gives a good perspective
Greg
73 Cuda
Brisbane, Australia
Offline dfrazz
« Reply #8 on: July 01, 2014 - 08:17:36 PM »
Dfrazz
I didn't know.  Thanks and hope it helps.
Offline crash340
« Reply #9 on: July 05, 2014 - 12:51:41 AM »
Here is a pic of my issue,
I have flipped the x pipe to now pont down, all good, happy with this, the EB cable naturally wants to sit about two thirds the way up through the pipe, if I put the cable either over or under it will rub on the pipes. I could relocate the hook rod on the trans crossmember higher I guess to hold the cables hard agains the floor, very near the drive shaft, this would get around the pipe issue and also hold the adjuster rod up high as its kind of hanging down right now begging for being torn off.
any words of wisdom?
Greg
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #10 on: July 05, 2014 - 12:52:35 AM »
oh, here is the pic,,, :banghead:
Greg
73 Cuda
Brisbane, Australia
Offline bert
« Reply #11 on: August 19, 2014 - 05:05:15 PM »
This is how I put my exhaust on but the cable are different too
Offline CudamanTom
« Reply #12 on: August 19, 2014 - 06:21:58 PM »
The cable arrangement is different from 70 to 71.
Nice setup BTW.  :2thumbs: :ylsuper:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #13 on: August 19, 2014 - 07:31:07 PM »
WOW! How much time do you spend polishing the exhaust? Looks good!  :2thumbs:
Offline Racer57
« Reply #14 on: August 19, 2014 - 09:51:27 PM »
That ain't the only thing that's different !!!    :clapping:
