Re-Gauging, need experienced input
Author Topic: Re-Gauging, need experienced input  (Read 3797 times)
Offline crash340
Re: Re-Gauging, need experienced input
« Reply #15 on: July 09, 2014 - 04:15:17 PM »
Ref adding a tach,Speedhut does a dual speedo/Tach in one gauge, uses GPS for Speedo, you can either have the large needle as a speedo or a Tach and the smaller needle the other pending how you order it, that way the Tach and speedo are right in front of you
Greg
73 Cuda
Brisbane, Australia
Offline Strawdawg
    • Vortex Buicks
« Reply #16 on: July 09, 2014 - 05:36:58 PM »
That's a nice option :)
Offline 360FISH
  • BS23H3B567746
« Reply #17 on: July 16, 2014 - 11:38:06 PM »
Wow, those are really great looking...
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline crash340
« Reply #18 on: July 17, 2014 - 06:47:17 AM »
Yeah, pretty cool, im planning on modifying a std instrument housing to fitt one of them along with oil, water,volts and gas to keep the original dash but have better gauges, will probably have to spin up some alloy tubes with flanges on them to mount the gauge in, cut the front of the tube to match the contour of the clear lens etc. dont want to build a new face, dont like the flat race look etc.
Greg
73 Cuda
Brisbane, Australia
Offline 360FISH
  • BS23H3B567746
« Reply #19 on: July 17, 2014 - 04:26:17 PM »
I'd be interested to see what you come up with... please take pictures and share when you get around to this project.
Thank you
Offline Mickm
« Reply #20 on: July 26, 2014 - 12:05:26 AM »
Crash340,
What you are doing is almost exactly what I have in mind. I want to have as close to stock looking instruments as possible but with more reliability and accuracy.
I have started mine and will post pics soon as I have something worth showing.
Thanks,
Mickm
MickM
Offline crash340
« Reply #21 on: July 26, 2014 - 05:21:58 AM »
Mick
it will be some time before I get to that, right now I have just purchased a complete dash minus all of the gauges, so I have the cluster housing, lens, bezel, basically I was going to purchase the gauges and figure it from there, big gauge will be a speedo with smaller Tacho with in it, smaller ones will be gas, oil, water and volts. What is in my mind is turn up some thin wall tubing with a mounting flange inside and a flange extermally to enable the tube to be screwed to the cluster housing, then cut the front of the tube to match the contour of the lens similar to the factory gauges. the cluster housing will more than likely have to have large holes cut through it for the back of the gauges etc but I have nothing hard and fast until I get the gauges, big task but I think well worth it, it will look factory until you look hard, much nicer than an aftermarket flat facia etc.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #22 on: July 26, 2014 - 08:59:13 AM »
I noticed they also have a speedo/fuel guage combo, I could see myself using that, then getting one of those redline tach's and putting it in the second slot where the fuel guage would normally be on my non-rallye cluster
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline crash340
« Reply #23 on: July 26, 2014 - 04:48:59 PM »
MM, actually thats not a bad idea! might steal that idea with my plan as I was having trouble deciding do I go big speedo small tacho or opposite on the one big gauge, having a large speedo and a full tacho gauge beside, albeit small in diam would be nice I think
Greg
Greg
73 Cuda
Brisbane, Australia
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #24 on: July 26, 2014 - 05:23:12 PM »
I officially informed my wife what I will be getting for my b-day hahaha. Then for Xmas I'll get the redline oil pressure guage to replace the factory clock!
« Last Edit: July 26, 2014 - 05:25:31 PM by moparman82 »
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #25 on: July 26, 2014 - 06:49:34 PM »
MM82 - I had redline put in a tach where the fuel gauge was and move that to replace the Alt meter, and install the oil pressure gauge in the blank space.  They also calibrated my speedo, reset the odometer since I'm restoring everything and polished the lens.  Very happy with their work, took about 4-5 weeks.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #26 on: July 26, 2014 - 10:28:19 PM »
Looks good dfrazz, you just reassured me I'm making the right decision
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
