Napa 268-3467 or
Cross Interchange Parts
Factory Number
MOOG K7014
AUTOSPECIALTY 09-83004
ELGIN 8669K
SEALED POWER 803-18669
CHRYSLER 2269679
CHRYSLER 2835842
Ok, it fit but not without a struggle. First problem was the shaft that mounts on the k-frame wouldn`t fit so I had to grind off about 1/16". Not sure if it was due to the thick washers supplied or the c-body is supposed to be longer? Once I got that fixed I bolted it up to find out the grease fitting is placed on the end and hits the header tube so I had to drill a new hole on the drivers side of the knuckle and weld up the original hole. It`s now bolted in and clears everything fine although I voided the lifetime warranty by modifying it but oh well.
