Josh, look at the bottom. Just posted on Moparts for July. Rods are under 500 and a free crank from me
375 bucks for good pistons
PISTONSPISTON BONANZA!!!!!!!!!!! FIRST PAID FIRST SERVED
ALL FORGED--ALL NEW IN BOX--CLOSEOUT!!!!
I am cleaning up the shop--these are all new in the box--boxes are nappy and have been around a while--all sold final sale no returns--that is the entire point of a close out sale--cut the heck out of the price and send them to new homes--
read with care --no returns, now step into the world of wonderful piston deals...
ROSS 383 030 forged flat tops stock stroke, stock rod--one set only $375 ( new at Scummit $590)
ROSS 400 4.375 bore ( a little over 030 over)
1.471 compression height, 6.76 rod length with .990 pin $375 ( summit $590+)
ROSS 383 stroker 060 over for 3.750 stroke--440 style crank with 383 length rod / stock 109 pin small 8cc dish so street compression easy breezy $375
ROSS CUSTOMS 4.378 bore ( just use 4.375 file fit rings) 11cc dish, 1.604 compression height, 109 pin you figure them out killer deal $300
ROSS 400 block for 451 stroker use 440 crank, 676 rod, 990 pin, 1.320 CH, 4.375 bore, DOME
These are the perfect race low deck piston--two sets $375 a set ( $600 new at Jegs etc)
DIAMOND 400 block for 451 stroker, 4.380 bore flat tops, 1.320 CH for 440 crank, 676 rod, 990 pin -- same as above but flat tops $375
All pistons will be shipped UPS ground-for flat rate $20 in lower 48 states
KILLER DEALS--FINAL SALE--NO RETURNS--ALL NEW IN BOX
Thanks
jdk@ctc.net
