Author Topic: Crush Can - Learn Something new everyday  (Read 4286 times)
Offline CUDA JAS
  • vroooooom!
Re: Crush Can - Learn Something new everyday
« Reply #15 on: July 05, 2014 - 07:35:44 AM »
Used on B & A bodys , just a shorter version & yes the tuff wheel fits on either
Ok got ya.
My Cuda had a tuff wheel when I bought it (20+ years ago) so I forget that they did not come stock with tuff wheel.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline marc7071
  • 1971 Dodge Challenger Convertible JH27G1B100192
« Reply #16 on: August 10, 2014 - 11:06:47 AM »
Another possibility:
Could just be something as simple as a superseded (revised part number) replacement part.
As a Chrysler parts man, I see this every day. Parts number changes and sometimes slight configuration changes are made for various reasons whether it be a vendor change or a design revision.
Happened back then and still does to this day. Always something to take into consideration when working with ANY part, including your 'tomato can'. ;)
Offline Fern
« Reply #17 on: August 10, 2014 - 12:11:25 PM »
How difficult is it to shorten the crush can?
Can it be done or better to find a B-body one?
« Reply #18 on: August 11, 2014 - 06:39:22 PM »
I suppose you can put it in a press & push evenly on it
Offline tommyg29
« Reply #19 on: August 12, 2014 - 04:25:53 PM »
It probably wont function exactly as intended in an accident, but what I did was cut out about a 2" section out of the middle, then welded the two halves back together, and the rest is simple bodywork: grind the high spots and fill in the low spots, prime and paint.
Two things to note.
First you must cut in the exact right spots of each "rib" so they will match when rejoined.
Second, you cant cut too much, so make sure you measure for clearance for your hands from your dash and the turn signal (I bent the signal shaft slightly to make it fit better). In my case about 1.5-2 inches was the max before my fingers would start hitting the dash.
If youre handy you could do it all over a weekend. Have to wait for stages to dry etc.
I dont weld so I took mine to a welder to attach the two halves. Did everything else and it wasnt too bad.
End result looks great.
« Reply #20 on: August 12, 2014 - 04:59:38 PM »
Interesting mod!  Good job, looks stock! :2thumbs:
Offline Fern
« Reply #21 on: August 12, 2014 - 06:04:05 PM »
Nice job  :2thumbs:
looks great, thanks
