Author Topic: Clunking Noise From Steering Column  (Read 1602 times)
Offline CUDA JAS
  • vroooooom!
« on: July 03, 2014 - 07:56:06 AM »
I have a nasty clunk coming form my steering column.
here is a video:
Any ideas what would be causing this.
I know its not the crush can, as I have pulled that off and still get the clunk when I turn the steering shaft.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline CudamanTom
Re: Clunking Noise From Steering Column
« Reply #1 on: July 03, 2014 - 08:08:28 AM »
Jason,
Sounds like a solid thud noise. Is the steering box under the hood bolted down tightly?
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #2 on: July 03, 2014 - 08:28:08 AM »
Is there play in the wheel before the wheels turn , the shoes inside the coupler could be inserted in the wrong direction , they will go in 2 ways but the wide part has to be horizontal so thereis no slack
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: July 03, 2014 - 08:35:11 AM »
Jason,
Yes, but I will double check.
I have never had the coupler apart, so I will assume it is correct.
That being said, it sounds to me like the noise is coming from inside the car, not under the hood.
74 'cuda 360/727
Offline anlauto
« Reply #4 on: July 03, 2014 - 08:53:26 AM »
Man...you need power steering :scared: Look at the fore arms on the guy... :-*
Offline ammo
« Reply #5 on: July 03, 2014 - 09:15:51 AM »
Never really looked over the column on my car but I assume there are bolts/bracket holding the column up?  are those tight?
1973 dodge challenger
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: July 04, 2014 - 08:47:02 AM »
Gee thanks Allan...I think.
I am working on the power steering. :bigsmile:
I never thought of that...I will check them.
Jason
74 'cuda 360/727
« Reply #7 on: July 04, 2014 - 09:59:03 AM »
Doesn't seem to be up & down movement just rotational  , if the shoes were in the couple wrong the wheel would have play 1/2 or so each way before it moved the wheels or steering box , , nothing should be clunking inside the column as it rotates so maybe in the mounting ?
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: July 05, 2014 - 10:41:04 AM »
Mounting bolts are all tight and there is no up and down movement in the column.
There is a little bit of play in the column, but certainly not 1/2 inch.
I am in the process of switching to power steering, so I will pull this apart and see if I can figure out what the noise is...just for fun.
Jason
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: July 16, 2014 - 10:41:04 PM »
So, a little update...I pulled the column out of the car tonight.  I disassembled it as I went.
I did not find anything obvious in the interior portion of the column.
I did however find this:
I wonder if that was it.
One of the reasons I am switching the column, was the very crappy looking weld on the shaft, it has always bothered me a little.  What I realized once I pulled the column out is that the shaft is not quite straight.  So I am thinking that has something to do with it too!
Jason
74 'cuda 360/727
Offline anlauto
« Reply #10 on: July 16, 2014 - 10:47:10 PM »
I have new rebuild kits in stock......I think :dunno:
