Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
modern headlights into challenger
« previous
next »
Print
Pages: [
1
Author
Topic: modern headlights into challenger (Read 3068 times)
kowalski
Jr. Member
Challenger=SCCA Trans Am Homologation Special
on:
September 25, 2005 - 05:42:15 PM »
I was reading an article about Joe Rogans (fear factor) 70 cuda and i read that the headlights are modern hi output headlights but they look like and fit like the old ones does anyone have any info on a headlight swap?
Logged
1970 318 bored .060 over edelbrock performer intake ported and polished 360 J heads 2.02 intake 1.60 exhaust double springs carter hi cap fuel pump edelbrock victor series water pump MSD 6AL flotech headers
gn300
Jr. Member
Re: modern headlights into challenger
Reply #1 on:
September 29, 2005 - 11:08:30 AM »
Quartz haligen h-4 headlight are all you need bosch, hella, or the best cibie no need to change anything but the headlight bulbs up to 100/180 watts but you would need a relay to run those bulbs.As long as they are aimed right they are unbeetable the first mod i ever did was cibie headlight ! And i took them out when i sold it!Cheepies in the JC witney catologe> dont lough they are better than stock.
Logged
ROMI
Full Member
71 Challenger R/T 340 4 speed, Lapeer Michigan
Reply #2 on:
September 29, 2005 - 01:23:49 PM »
Can you elaborate on the relay ?
Logged
gn300
Jr. Member
Reply #3 on:
September 29, 2005 - 08:02:56 PM »
Relay uses low current 12volt from toggle switch to activate lights ,sort of takes the draw away from the switch so it wont overheat.
Logged
ROMI
Full Member
Reply #4 on:
September 29, 2005 - 08:44:51 PM »
Is this an "Auto Zone" type device for converting older cars? Where do you get one?
Logged
gn300
Jr. Member
Reply #5 on:
September 30, 2005 - 02:18:25 PM »
Had time to think a little A headlight relay uses 12 volts directly from the battery to the relay from the relay to the lights the switch just triggers the relay to activate the lights. It will not make them brighter but it will save your headlight switch from over heating of you use high power lights!Get the parts guy to check the light book for h-4 quartz haligon lights.Bosch, lucas, cibie , are but some of the Brands.Relays are at the parts store as well!Be warned once you put them in and aim them properly you will be hooked they are great have a "cut off" line and a well focused pattern!
Logged
ROMI
Full Member
Reply #6 on:
September 30, 2005 - 10:53:41 PM »
Thanks gn, I'm going to check into it because my Challenger lighting really needs some help after driving my Vibe with it's bright lights.
Logged
cudahob
Guest
Reply #7 on:
October 08, 2005 - 07:44:05 AM »
Here is Joe's Cuda
Logged
gn300
Jr. Member
Reply #8 on:
October 08, 2005 - 12:47:36 PM »
Looks like typical quartz halogen replacement light with the newer style blue bulb. I have tried those bulbs but prefer the white ones the blue ones show funny shadows in the road for some reason!
Logged
Grancoupe
Full Member
Reply #9 on:
October 10, 2005 - 11:11:04 PM »
Just I case you haven't seen these, I noticed them in a JC Whitney catalog and looked them up on the web. It seems the bulbs aren't actually bulbs but housings for 9003/H4 Halogen bulbs. Is this what you guys are talking about?
[url]http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2003803/showCustom-0/p-2003803/N-111+10201+600002821/c-10101
[/url]
http://
Logged
gn300
Jr. Member
Reply #10 on:
October 11, 2005 - 10:49:20 AM »
Page wouldn't open but more than likley yes i've seen them in thier catolog before but the more recognizable the name the better the light ie bosch, cibie, lucas, hella,just replace the old ones and line them up and you will be illuminated!
Logged
HemiDog
Sr. Member
Do not Assume!
Reply #11 on:
October 11, 2005 - 12:43:07 PM »
I did have a big write up on this that I was going to post, but I found the website I was going to refer to. This should straighten out this topic.
http://www.madelectrical.com/electricaltech/brighter-headlights.shtml
Don't forget that the reason they were getting 14V was because the car was running the alternator puts out more that 12V....
Painless Wiring also sells relay harnesses.
Last Edit: October 11, 2005 - 01:02:19 PM by HemiDog
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
